586,108 active members*
3,173 visitors online*
IndustryArena Forum > CAM Software > Vectric > Cutting 2”x2” squares 1/8” thick aluminum
    Anyone familiar with cutting 1/8” aluminum. I’m trying to get some different set up options. Right now I run around 300-1000 placards at a time and then have about 20-25 hrs To clean up all the parts. I’m looking for a setup that would have a next to mirror finish on all edges and no burr and ideas would help.
    Re: Cutting 2”x2” squares 1/8” thick aluminum
    I’m currently using a multi cam 1000 flatbed vac router. Programming through enroute.
    Dec 2013
    5717
    My best suggestion is a sharp 3 flute, aluminum cutting, carbide end mill. I personally like the Onsrud cutters, but there are many others. Use heavy spray mist, with good airflow to remove the chips. Or use flood coolant. Make a roughing pass, leaving about 0.005''/side for a cleanup pass. Adjust your feed and speed for at least 0.001'' feed per tooth on the finish pass. The edges will look polished when finished.
    Jim Dawson
    Sandy, Oregon, USA
  1. Cutting 1" thick aluminum on CNC
    By Matthew_ in forum DIY CNC Router Table Machines
    Last Post: 12-12-2017, 02:15 AM
  2. Manufacturing a 300 X 250 2mm thick aluminum lid...
    By rvndraju in forum Casting Metals
    Last Post: 11-16-2016, 09:26 PM
  3. Replies: 5
    Last Post: 09-12-2012, 03:09 PM
  4. Rockwell blade runner good for cutting 2-3" thick aluminum?
    By autobot in forum Uncategorised MetalWorking Machines
    Last Post: 02-03-2012, 02:50 PM
  5. Best Mill for 1" thick Aluminum?
    By gtslabs in forum Uncategorised MetalWorking Machines
    Last Post: 01-01-2004, 04:37 AM
