586,094 active members*
3,895 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > CS-D508 closed loop stepper drive current
    Oct 2012
    16
    HI I have just setup an Emco lathe with an ELS with ball screws and closed loop steppers. For the X I have a CS-D805 driver and a nema 17 CS M2 1708 (leadshine) motor. I am new to leadshine closed loop steppers by my understanding is the current is set automatically? If this is the case it is not working correctly as the motor gets very hot (as in burning skin hot, I don't have a thermometer in my workshop but way too hot) Do I need to get the cable so I can change something in the driver setup?
    thanks
    Luke
    May 2015
    38
    Re: CS-D508 closed loop stepper drive current
    Hi Luke,
    Thank you for supporting Leadshine products.
    The motor CS-M21708 is rated 2.5A, you need a tuning cable to set a smaller current in CS-D508 to avoid motor too hot.
    Please try to contact your direct supplier for a tuning cable "CABLE-PC" to make some tuning work, thanks.
    Best regards.
    Jan 2018
    1516
    If the motor is getting THAT hot are you sure it's up to the job and not too small?
    Are you sure there is no tightness/binding anywhere.
    As with brushless RC stuff.- Motors get supplied the current the motors ask for. If you gear them up or make them too tight they ask for more then they get too hot.
    It's worth you having the cable by the sounds of it.
    DB9 (serial RS232) to RJ11 connections.
    I hear different vendors wire them with different wiring so make sure what you get matches the connection terminals shown in the driver manual.
    If you don't have manual then Google search:
    leadshineusa.com › Down › CS-D508_m3.1.pdf.
    It's top result.
  1. Wantai SS880 closed loop stepper drive tuning
    By danilom in forum Stepper Motors / Drives
    Last Post: 03-12-2020, 03:07 AM
  2. Replies: 0
    Last Post: 12-17-2015, 05:27 AM
  3. Open Loop to Closed Loop Stepper Conversion
    By beamhome in forum Stepper Motors / Drives
    Last Post: 03-09-2014, 11:27 PM
  4. Emc and cnc drive.com closed loop
    By matttargett4 in forum LinuxCNC (formerly EMC2)
    Last Post: 02-28-2013, 03:53 PM
  5. Replies: 0
    Last Post: 03-13-2012, 11:15 PM
