586,493 active members*
1,625 visitors online*
    May 2018
    85
    Z-axis weight compensation
    My CAMaster CNC had quite a heavy Z-axis with a spindle and two outboard 1-3/4 HP routers. It had a pneumatic cylinder to assist the stepper with lifting the Z car.
    My DIY project is lighter but I’m wondering if it’s worth including a similar weight compensating system. The cylinder is in place (it was originally the only motivation on the Z axis of this P2P drilling machine) and in fact it is mostly working. However the extra mass and complexity may be unnecessary on my build as the only major weight on the Z car is the 2.2 HP spindle. So far the servo doesn’t seem to have any trouble lifting the mass of the spindle.
    I am having an issue with the regulator not bleeding off pressure when the cylinder compresses, so the servo must actually apply increasing force to move the spindle downward.
    Aug 2015
    142
    Re: Z-axis weight compensation
    2,2 kw spindle dont weight too much , so u dont need a weight counterbalancing .
    Apr 2013
    I second the previous reply.
    In my experience, if the motor is not struggling to raise the Z, no need to help it any.
    May 2020
    8
    I wanna know what Z-axis is made of? AISI 52100 or other steel grade?
  1. Question about PRO 4896 and weight of the Z axis
    By talonosi in forum Avid CNC
    Last Post: 03-08-2015, 12:56 AM
  2. Z Axis Weight
    By kolias in forum Open Source CNC Machine Designs
    Last Post: 11-07-2013, 03:27 AM
  3. Z Axis weight?
    By DistortedDesign in forum Stepper Motors / Drives
    Last Post: 06-29-2013, 01:51 AM
  4. Calculate Max Weight of Y/Z axis
    By samsagaz in forum DIY CNC Router Table Machines
    Last Post: 11-06-2012, 03:32 PM
  5. z-axis couter weight
    By yoopertool in forum DIY CNC Router Table Machines
    Last Post: 11-05-2007, 10:50 PM
