603,936 active members*
3,667 visitors online*
    Jul 2015
    Wood working lathe
    Hello all,
    I've been looking at getting into a hobby of woodworking and have a few questions.if anyone can help me would be greatly appreciated.
    1. I've seen a few lathes on-line and was wondering what ex-gst and inc-gst mean?
    I did a Google search and came up with nothing.
    2. What's a good lathe for a beginner to start out with?
    3. Are there any good CNC routers and lathes out there as well?
    Jun 2020
    18
    Re: Wood working lathe
    Sorry, I can't answer your first question, but I will answer your other two questions below.
    It all depends. It depends on your hobby. For example, if you like to make smaller objects, then a micro lathe may be just what you want. If you like to make larger and more refined structures, then you may need a larger machine to satisfy your hobby.
    Which is the best CNC router machine? Computer Numerical Control (CNC) is a way to automate the 3D cutting and milling process. The best CNC router machines allow you to do factory-level processing in a small home store. By using the computer and software to guide the predetermined cutting process, the CNC router machine can provide precise and consistent work as required, as well as precise replication and high productivity. The CNC router allows you to use wood, plastic, foam, and many other materials to make carvings, decorations, panels, signs, frames, shapes, furniture-your imagination is the only limit.
    Here is a review of the top 5 CNC routers. Learn more: Top Best CNC Router Machine of 2020(https://forsuncnc.com/top-best-cnc-router-machine/)
    Apr 2021
    Hello!
    2.What's a good lathe for a beginner to start out with?
    (Metal Master) I used it!
    3.Are there any good CNC routers and lathes out there as well?
    (I think yes)
  1. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  2. 3d wood working bit
    By modric in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 08-09-2013, 07:37 AM
  3. 3D Designs For Wood Working or Wax
    By saratbabu in forum Commercial CNC Wood Routers
    Last Post: 01-08-2011, 03:43 AM
  4. DIY Wood working machine
    By shulio in forum DIY CNC Router Table Machines
    Last Post: 04-03-2009, 06:36 AM
  5. 5'x10' cnc wood working machine
    By haku in forum DIY CNC Router Table Machines
    Last Post: 01-18-2009, 09:44 AM
