586,903 active members*
2,807 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Fusion 360-CAM -Ridged Tapping- Metric Tap programming into tool library, need help.
    Jan 2013
    8
    In Fusion 360 CAM, you can program a 1/4 - 20 pitch at .05. But if you look at the example tools for metric, example M4 0.7, it lists the thread pitch at 0.7 and the actual tap diameter at 4mm. Another example is 10-32. 10 is wire gauge, 32 is per inch,, 1/32. You enter the pitch at 0.03125. Metric as I can tell this does not hold true. I'm snapping metric taps, and not ANSI. Thank you in advance for helping if you can. Show me the math
    Respectfully,
    Sean
    Nov 2013
    4462
    Re: Fusion 360-CAM -Ridged Tapping- Metric Tap programming into tool library, need he
    you are facing the problem of 'thread engagement'.
    You might imagine that if you want to form a 6mm threaded hole, that is 1mm pitch, that you would drill the hole so that 100% of the thread is formed,
    that is 6-0.866=5.13mm. That would be a mistake, you'll break the tap.
    Its normal to make the hole larger, commonly for 50% thread engagement. For high strength applications like head studs on a car or seatbelt bolts
    the 60%-65% is common. But that is about as much as you can do with a tap, any more engagement and you'll break it.
    Very high strength aircraft threads often have 85% engagement or more, but those threads are milled or rolled, expecting to tap then is unrealistic.
    This speed/feed calculator has a very useful thread database:
    https://hsmadvisor.com/
    The bottom line is if you get greedy and try to achieve high engagements you will break taps.....I've broken plenty trying to do just exactly that.
    Craig
    Jan 2013
    8
    Craig,
    Thank you for taking the time. I total get what you are saying. Although I think I have more than likely phrased my question poorly. See attached pics.Attachment 443660Attachment 443662. If you notice, the programming to the ANSI tap, (1/4-20) to get the correct response from the rigid tapping, you divide 1 by 20 threads per inch and place that in your CAM. When doing metric, "according to Fusions examples" you just put the metric listing, M4 0.7 you put 0.7mm in the pitch. Why is it that when you enter ANSI you don't just put 20 like metric. I know for a fact that the 0.05 in the pitch settings work well. In short, why a direct entry of 0.7mm? Hope this clears up my question. Thank you again for taking the time.
    Dec 2008
    3117
    Unless there is a check to say this is a metric tool
    ... it could be a post error
    You are placing a metric value into an inch setting
    0.7" pitch is huge, it needs to be converted to an imperial pitch
    ie try these pitches.. turn the metric tool into imperial
    M4x0.7p = 0.0276" pitch
    M5x0.8p = 0.0315" pitch
    M6x1.0p = 0.0394" pitch
    inch pitch = metric pitch ÷ 25.4
    Oct 2010
    171
    Or don't convert it (if you're in inch) and just enter ........ 0.7mm ........ as the input value. Fusion will convert.
    As Superman says: If you're running your machine in inch mode, you might have to enter your M4 tap data like this: (this is how my M4 tap is set up in the tool library)
    I just did a quick test in the tool library and added another metric tap (10mm x 1.25). I just left everything at inches, except entered: "10mm" as the diameter, and "1.25mm" as the pitch. The value was instantly converted to inches when I tabbed away from that field.
    PM
  1. Tool Library Tips/Tricks Fusion 360
    By tbev in forum Autodesk CAM
    Last Post: 12-18-2015, 04:11 PM
  2. Metric tool library
    By wbleeker in forum SprutCAM
    Last Post: 03-27-2015, 07:57 PM
  3. Standard tapping and Metric Programming.
    By Dull Tool in forum MetalWork Discussion
    Last Post: 03-12-2013, 11:23 PM
  4. ridged tapping for puma 240
    By outcastproducts in forum Daewoo/Doosan
    Last Post: 03-28-2008, 12:11 AM
  5. Help Ridged tapping with 1/4-18 NPT tap please!
    By jrudicel in forum MetalWork Discussion
    Last Post: 01-18-2007, 01:09 AM
