603,958 active members*
2,311 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Standard tapping and Metric Programming.
Results 1 to 5 of 5
    Jan 2007
    12
    Howdy folks. Found this site and there is a world of knowledge here. I thought this would be the place for a question I have.
    What are you guys doing as far as programming a standard (inch) tap while using metric programming? We are an all metric company so we have set up our machines that way. Every now and then we have to tap an English thread and we have just decided to hand tap it outside the machine.
    Are you guys using tapping heads or attachments? That is the one way I thought this may have worked, with a self reversing tap head and using a feed in, feed out cycle. If what I am thinking is correct, can some one recommend a readily available tapping product.
    Thanks in advance.
    My name is Louie by the way.
    Mar 2003
    4826
    Louie by the way
    You should be able to convert the imperial threads per inch to a metric pitch or metric feedrate. I do just the opposite for tapping metric pitches while in inch mode.
    Do you tap metric threads using the tap pitch directly or do you calculate the required feedrate (mm/min) at your chosen rpm?
    First you get good, then you get fast. Then grouchiness sets in.
    May 2006
    265
    We work in metric but we still do alot (most) inch threads..
    ex 1"-8nc
    1"=25.4mm
    25.4/8= 3.175
    3.175mm = metric pitch
    Jan 2007
    12
    Thank you guys very much. It's much appreciated. :cheers:
    Jan 2007
    243
    Definately check here: Tapping Calculator
    www.WebMachinist.Net
    The Ultimate Online Source for Machinist Related Stuff!
  1. Rigid Metric tapping... Need a bit of help
    By saabwagon in forum Haas Mills
    Last Post: 01-23-2013, 06:26 PM
  2. metric tapping
    By kurt_laughton in forum G-Code Programing
    Last Post: 10-02-2008, 03:54 PM
  3. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
  4. VMC Tapping Head programming - easiest way?
    By DCparts in forum Mastercam
    Last Post: 05-03-2006, 01:56 AM
  5. tapping head vs hand/cordless tapping machine....
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2005, 02:10 AM
