586,096 active members*
3,113 visitors online*
Thread: Fanuc 0i-TF
    Fanuc 0i-TF
    Hello. Can anyone help me to find out the home position code for a cnc lathe with Fanuc control 0i-TF.
    when i put G28 U0.0 W0.0, the tool moves towards the chuck and the x and z values are zero here. But if i use G30 U0.0 W0.0 the tool moves away to a home position but the values of x and z are not showing zero. My question is does htis control need a home position code or else the parameters are not correct.
    Please let me have your opinions.
    Dec 2012
    395
    Re: Fanuc 0i-TF
    Don't use G30, better is G53 G00 X0. - G53 G00 Z0. if the G28 doesn't work.
    Regards.
    Heavy_Metal.
    Re: Fanuc 0i-TF
    It is possible that zero has been set to be the center of the chuck. (Which you probably can never get to) Check parameter 1240 if it has a value in it then they are offsetting your machine zero position. Also check parameter 1815 and if APC & APZ are set then homing isn’t necessary.
    Dec 2018
    5
    Re: Fanuc 0i-TF
    Change G30 point
    1. CNC Mode
    2. Press MDI
    3. Press offset button until Setting handy and parameter write menu appers
    4. Write 1 on Parameter Write then input
    5. Press System until serch parameter is popping up
    6. Write 1241 ( OBS Dont press INPUT after writing 1241) press No search on screen
    7. Write your value in the cells and press input.
    8. Go back and change parameter write to 0
    9. Done.
  1. Fanuc tape cut mate fanuc om paramter setting for cutting materials
    By Vijay040engg in forum EDM Discussion General Topics
    Last Post: 08-27-2019, 10:00 AM
  2. Replies: 5
    Last Post: 04-20-2019, 02:31 PM
  3. Replies: 12
    Last Post: 12-26-2016, 10:31 PM
  4. Replies: 8
    Last Post: 09-25-2014, 02:58 PM
  5. Replies: 0
    Last Post: 01-28-2014, 04:41 AM
