586,082 active members*
3,769 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > VisualMill demo evaluation videos
    https://www.youtube.com/playlist?lis...rGhd5_SookDpv5
    Here is a playlist I made of three YouTube videos where I evaluate VisualMill. I don't use a demo part dreamed up by their marketing department, but a part made by a machinist mechanical engineer buddy that was meant to be hard to program. I did a similar series for the free SolidWorks CAM that comes in 2018 and later releases. I posted that in the forum for SW CAM.
    I do like the way VisualMill works, but my particular installation was unstable. It kept changing stock allowances from 0 to 1. If I set any operation to be all finishing or all roughing, it would add some rapid Z moves a foot or two through the part. This is likely because the installation failed, saying it could not install one of the Microsoft Visual C++ packages since I already had a newer version installed. This might have come from my TurboCAD, or SonyVegas, or CAMtasia or gosh-knows what program.
    This is part of my learning CAM and in preparation for buying a CAM program. I won't be using the free SW CAM, since it does not have a perpetual license. When you stop paying SolidWorks maintenance, the CAM program stops working. I have an Avid Benchtop Pro, so I am hoping to do light 2- and 3D machining in aluminum.
    Paul
    Re: VisualMill demo evaluation videos
    Wow! Thanks for the info!
  1. Evaluation?
    By glengeniii in forum ZW3D CAM
    Last Post: 07-29-2013, 02:14 PM
  2. Visualmill demo problems
    By toothandnail in forum Visual Mill
    Last Post: 09-30-2012, 03:02 PM
  3. Your evaluation and help please.
    By Deskin in forum DIY CNC Router Table Machines
    Last Post: 01-06-2011, 03:58 AM
  4. Getting MFC error in VM6 DEMO evaluation
    By Khalid in forum Visual Mill
    Last Post: 10-07-2008, 03:56 AM
  5. Sherline/Maxnc or other desktop mill demo videos?
    By david90 in forum Benchtop Machines
    Last Post: 02-16-2008, 04:55 PM
