586,717 active members*
3,117 visitors online*
Page 2 of 8 1234
Results 21 to 40 of 151
  1. #21
    Apr 2010
    215
    Re: Gully's new 3x3 steel CNC router build
    Nice looking bit of kit there Peter
    Bath or hydro bath for disabled?
    I work in Hospital engineering these days and have seen very similar setups
    Maybe you made them.
    Striving for medeocrity..and achieving high scores!
  2. #22
    May 2015
    686
    I buy my nutserts from Rivnut Australia so what am I using???
    I've used some that are 10mm OD but these ones are 9mm OD which I learnt the hard way with laser cut holes.. Mostly I use them with powdercoated parts and there is a bit of an art to choosing a hole size that allows for the powdercoat without needing a hammer.
    I'd happily use them for linear rails but I'd like a recess that allowed the rail to sit flat on the frame, not on the nutsert.
    How have you found the rails sit on the nutserts v's an accurate finish?
    Rod Webster
    www.vehiclemods.net.au
  3. #23
    Apr 2010
    215
    Hi Rod,
    Thanks for dropping past.
    I'm using flush finish nutserts. You just need a very small countersink at the top of the hole for them so the rail will be sitting on the steel not the nutsert.
    If I need to epoxy level the surface they will be well below
    Attachment 445902
    For powdercoat finish I use to always put them in prior to powdercoat and either put sacrificial fixings into the thread or stuff the hole with balled up tape to keep the powder out.
    only occasionally did I ever need to run a tap through to clean out a thread
    Gully
  4. #24
    Jul 2018
    6433
    Hi Gully - it's a birthing bath. I have just redesigned it for use in residential care as well. Peter
    Talking about welding , I want one of these.
    https://www.youtube.com/watch?time_c...ature=emb_logo
  5. #25
    May 2015
    686
    Nah, It must be a taste thing, I used to send this part out to be lasercut and they powdercoated it after inserting the nustsert. But now I cut it on my plasma cutter out of waste from another job so its free now. I much prefer the look of a nice shiny unpainted nutsert. In fact I found one of the old style today and wondered if I could sell it!
    I'll look for some of the flush mount ones. They sound handy.
    Rod Webster
  6. #26
    May 2011
    790
    Quote Originally Posted by gully View Post
    Flow drilling!
    Oh my giddy aunt on my budget I would need to sell a kidney.
    I don't know what kind of shop equipment you have, but in one of the videos I posted, he's using a bridgeport mill, a fairly common thing, I don't know, you might have one?
    Doesn't look like he's using the specialized bit holder either, just the bridgeport, and the flow drill bit?
    One M5 or M6 bit costs around 35 to 50 USD on EBay including shipping. Might be worth the experiment to learn a new trick. Maybe not.
    Never been a fan of tapping light wall tube, I have used nutserts / rivnuts whatever you like to call them locally to hold down linear rails on tube in the past and they have been rock solid as long as you drill the correct size hole for them, nor have I managed to ever strip one out.
    It's simple and it works.
  7. #27
    Apr 2010
    215
    Hi NIC 77
    I must admit it looks a very cool method of putting holes in tube to give extra tapping material.
    I sold a lot of my metal working equipment when I closed my business down around 8 years ago.Just the basics these days, It looks like it would still work OK with a good drill press though.
    The tube I'm using had a slight convex to the walls so I ran the stock through my finish sander with a 40grit drum on it to remove most of the hump (poor mans version of precision surface grinding) so It's nominal 2.5+mm wall now
    nutserts have been my go to threaded fixing for any stock 3mm thick or less for a long time because I find them to be a reliable anchor point. that plus I'm too lazy to tap out all those holes.
    There will be plenty of parts requiring tapped threads later in the build.
    Gully
  8. #28
    Apr 2010
    215
    Peter
    My wife is a nurse and worked as a midwife for many years before getting into teaching nursing at Uni
    Showed her your tub. she thought it was brilliant.
    Gully
  9. #29
    May 2015
    686
    Yeh, I looked to. You need to make sure you have enough RPM by the look. I'm not sure if my little mill is fast enough at 1800 rpm https://f.nordiskemedier.dk/2lnj8im6qg3odipa.pdf
    A M6 bit and tap would set you back about AUD $55 on AliExpress. See this supplier
    https://www.aliexpress.com/store/173...49db1ba1bpBtTY
    For a quick test you would not need the tool holder with heatsink and fan.
    I'm tempted to try but I want to do ally which they say needs 50% more speed.
    Rod Webster
  10. #30
    Apr 2010
    215
    Just realized that I never posted the concept render of what the machine should look like completed (how rude)
    Attachment 445984
    The spindle can overhang the the front of the bed up to 70mm so I can edge machine parts and also put a small 4th axis there at some point in the distant future.
    There is also a recess to place the 4th axis under the spoil board or to put deeper parts to clear the gantry or fit some sort of vacuum hold down system. So I have plenty of future options available
    Actual cut area is around the 1050 x 1050+mm mark, so I'm selling it short calling it a 3x3
    Gully
  11. #31
    Apr 2010
    215
    Weekend tinkering has the gantry rough assembled
    Attachment 445998
    Will try to start on the end support mock ups next week end
    Gully
  12. #32
    Jul 2018
    6433
    Hi Gully - Wheels and an apron - A classy design 5 stars. Peter
  13. #33
    Apr 2010
    215
    Not a lot to offer up this weekend
    Cut out a pair of mock up gantry sides from 18mm MDF
    Spent some quality time cutting up the thick walled aluminium C channel that make up the spacer between the inner and outer gantry side then drilling and tapping to suit
    Forgot how long it takes to do all that stuff.
    Can look forward to doing it all over again next weekend for the other end
    Gully
  14. #34
    Apr 2010
    215
    Managed to get a bit more done this weekend between house and garden maintenance.
    Finished up any CAD adjustments and cutting out the mock up gantry sides. Also finished drilling and tapping out the aluminium channel spacers
    I now have the gantry sitting nice and square on the sides, Even managed to jag proper alignment of the stepper shaft to the coupler without any adjusting.
    Attachment 446796 Attachment 446798
    As Chairman Dan is sending us all into tighter lock down as of tonight, chances of being able to get steel stock, fixings etc will be very limited (non existent?) for the next 6 weeks and beyond.
    Will need to go through what stock I have in my workshop but should be able to finish up most of the gantry while us Vic's are sulking in the naughty corner.
    Stay safe.
    Gully
  15. #35
    Apr 2010
    215
    Another cold and wet weekend in lock down.
    This weekends task: Rough out the Z axis carriage set it up on the rails and have it running smoothly and square to the front of the x axis gantry along its length.
    Attachment 446980 Attachment 446982 Attachment 446984
    after a bit of tweaking it runs smooth and square from end to end both by hand and also driving the ball screw I'm sure some shimming will be needed during final set up, but as of now we are right in the ball park
    Will spend the rest of my time today tidying up the extrusion ends and doing some CAD revisions.
    Need to find and order some 8 or 12mm thick aluminum off ebay that's big enough to cut the front plate out of.
    Stay safe,
    Gully
  16. #36
    Apr 2010
    215
    Back at it again today.
    This lock down weekends task: Manufacture a working Z axis
    Have not been able to source any 8 or 10mm aluminium stock in a suitable size which is a pain, so it will have to wait till I can get out and about.
    To keep things moving I machined temporary mock up parts from 8mm phenolic board
    All went together nice and square with no binding so I'm a happy camper today.
    Attachment 447214 Attachment 447218 Attachment 447216
    Gully
  17. #37
    Jul 2018
    6433
    Hi Gully - What is the phenolic board? and where did you get it? cheers Peter
  18. #38
    Apr 2010
    215
    Hi Peter
    Solid Phenolic Compact (SPC), commonly referred to simply as phenolic resin table top, is one of the most durable surfaces for heavy-duty lab workbenches and casework countertops.
    The phenolic board I'm using started out life as the end panel on a hospital bed
    Its like a very thick and stiff laminate made up of an impregnated paper or glass film of some sort.
    Several of them were getting binned at work so waste not want not I say.
    Gully
  19. #39
    May 2011
    790
    That's a good reminder, I need to find myself some phenolic. This is also referred to as garolite? I'm not an expert on it. I know I can get it on eBay. I thought it normally came in red or green?
    I know it can be used as the bed on a 3d printer for printing nylon without heating the bed.
    For example, the very expensive markforged mark 2 printer does not have a heated bed. I believe it just uses a sheet of phenolic as the print surface.
    Beyond that, I have no idea what the structural properties are, but it would be interesting to learn more about it.
  20. #40
    Jul 2018
    6433
    This company has always had good data sheets on plastics - Peter
    https://www.professionalplastics.com...oven%20fabrics.
Page 2 of 8 1234
  1. Router home build Australia. Solid steel build
    By 80gus in forum DIY CNC Router Table Machines
    Last Post: 05-03-2020, 09:24 AM
  2. Diy steel router build
    By mkc2 in forum Australia, New Zealand Club House
    Last Post: 03-11-2014, 02:20 AM
  3. Steel 1.2m*1m Router build
    By Jtepper in forum DIY CNC Router Table Machines
    Last Post: 01-18-2013, 08:20 AM
  4. New 4x8 Steel CNC router build
    By Ernie34 in forum DIY CNC Router Table Machines
    Last Post: 11-25-2012, 01:41 PM
  5. First Router Build - 4x4, steel, R&P
    By cxixer in forum CNC Wood Router Project Log
    Last Post: 02-09-2008, 09:15 PM
