586,103 active members*
3,446 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > Maho MH800C 5axis Philips 532 - B02 alarm (measuring system alarm)
    Hello All,
    Our company bought this used machine around 2 months ago and we didn't power it up since last week.
    Machine parameters are still there. I tried to bring the axes to RP, x,y,z were ok but axis B (turning rotary table around y axis) wont move at all. neither manual nor with RP command. If you try, the hydrolic will power off.
    When i try to RP axis A (rotary table), the table wont stop moving!
    Any suggestion?
    b.t.w with the machine we got a 3axis vertical postprocessor. What should we do for a 5axis processor? should we buy it from DMG MORI? or it can be downloaded?
    Thanks alot,
    Afshin
    Re: Maho MH800C 5axis Philips 532 - B02 alarm (measuring system alarm)
    Now this error (B02) comes at the beginning and wont let the hydrolic to stay on.
    Nov 2015
    4
    [QUOTE = afshin1978; 2389714] Ova pogreška (B02) dolazi na po?etku i ne?e dopustiti da hidrolik ostane. [/ QUOTE]
    Attached Files Attached Files
    Quote Originally Posted by afshin1978 View Post
    Hello All,
    Any suggestion?
    Thanks alot,
    Afshin
    B axis encoder was damaged (not sure about the cause). Encoder out, B axis read out, and now it works with a vertical 3axis postprocessor.
    Now I wonder if anyone has a 5axis postprocessor or a 3axis horizontal?
    Best regards,
    Afshin
    Attached Thumbnails Attached Thumbnails WhatsApp Image 2020-09-05 at 2.37.33 PM.jpeg   WhatsApp Image 2020-09-05 at 2.38.18 PM.jpeg
  1. Homing Options, and Safety Relays MAHO MH800C
    By Burgs in forum CamSoft Products
    Last Post: 01-16-2018, 09:16 PM
  2. SYSTEM ALARM 945 SERIAL SPINDLE (1CH) ALARM
    By Platino in forum Controller & Computer Solutions
    Last Post: 04-16-2015, 01:42 AM
  3. Maho 700 & Philips 532 - not started, alarm A02
    By sliver123 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-30-2014, 07:10 PM
  4. 536 Servo alarm Fanuc Tape Cut W1 Wire EDM 5Axis
    By anoop.kp in forum EDM Discussion General Topics
    Last Post: 05-29-2012, 08:35 PM
