Hello all,
I have Mach3 and just purchased the G540 driver board. It is all up and running and does great. I had to upload the G540 xml file into Mach3 and now when I open a cut file it looks so much bigger than it should. In other words if the actual parameters for the material is 5 inches square, the gcode is trying to cut it at 20 inches square. Mach3 has a cut preview window and it only shows a very small portion of the actual file because it is so big.
