586,112 active members*
2,999 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Need some advise on best ball end mill and strategy for finish pass on aluminum
    May 2013
    167
    I'm working on a job that needs a fairly decent finish pass ( it's a mold for a lead fish weight )
    I'm attaching a photo of the piece to help explain it better.
    Basically it has two cutouts that are about 1 1/4" diameter and about 20 inches long.
    Currently I'm using a 1/4" ball tip end mill for the finish pass.
    I'm doing a .01" step over
    It's producing a really nice finished product, but I'm trying to get the milling time down on this.
    Currently Its taking about an hour to do the finish pass on each side of the mold. ( Each side of the mold has 2 of these cutouts )
    So the question is.... is there a more efficient tool I should be using?
    Here are some of my other settings for the 4 flute ball end mill
    RPM: 9167
    Surface Speed: 600
    Cutting Feed Rate: 95
    Feed Per Tooth : .0026
    My maximum RPM on my machine is 10,000
    Thank You...
    Kent
    Attachment 446884
    Apr 2004
    5737
    Re: Need some advise on best ball end mill and strategy for finish pass on aluminum
    If you could use a bigger-diameter ball end mill, it would go faster. If there's room for it, it will also leave smaller "cusps" between passes of the tool. You generally want to use the largest tool that will get into the details you need.
    Andrew Werby
    Website
    May 2013
    167
    Thanks for the info Andrew...
    I will do some test cuts with some larger sized ball end.
    How many flute do you recommend for finish pass on aluminum ?
    Thanks again,
    Kent
    Apr 2004
    5737
    The normal bit you'd use would be a 2-flute, in climb mode. If you've got a lot of "stick-out" and want a stiffer bit you could use a 3-flute - just remember to drop the RPMs by a third.
    Andrew Werby
    Website
    Aug 2020
    there is a discussion about this subject on C3D community. The discussion tile is Speeds, Feeds, Power, and Force (SFPF) Calculator. They provided a free Excel spreadsheet that facilitates the estimation and logging of CNC machining parameters and performance. The three tabs at the bottom left of the workbook access worksheets showing estimated parameters for a 60,000 RPM HF Spindle, the Makita 0701 Router, and Dewalt DWP611 Router in Shapeoko 3s. The maximum spindle/router speeds were used on each sheet to minimize cutting forces. The same 1/8" 3 flute endmill with 0.25" DOC and 0.005" WOC in 6061-T6 aluminum with ~0.001 (IPT) chip-load was used for all three.
    Attached Thumbnails Attached Thumbnails e58d43ead8867ae9fe018f6e8b6a4abfbe8cda33.jpg
  1. Replies: 12
    Last Post: 01-08-2019, 06:41 PM
  2. Finish pass?
    By budpage in forum CamBam
    Last Post: 07-12-2011, 06:45 PM
  3. surface finish with a ball mill
    By david rendon in forum CNC Tooling
    Last Post: 05-26-2011, 03:50 PM
  4. Ball Screws for custom mill, need advise
    By nateman_doo in forum Benchtop Machines
    Last Post: 12-08-2010, 05:33 PM
  5. Is it possible to finish flats with end mill and all others with ball mill?
    By CanSir in forum Uncategorised CAM Discussion
    Last Post: 08-18-2010, 07:38 PM
