588,627 active members*
5,559 visitors online*
    Apr 2007
    EMC2 - Step/Direction Change Precharge
    Hi to All,
    I've read some time ago, but I don't remeber where, how to set up optocoupled Stepper drivers.
    My Drivers need some precharge (steady signal before pin change).
    Anyone can tell me some more info about it?
    Many many thanx
    Andrea
    Apr 2005
    1778
    Andrea,
    If you still need an answer to your question, you might try the IRC channel for EMC2. You can find the info at the EMC2 website.
    http://www.linuxcnc.org/
    Alan
    Aug 2007
    7
    EMC2 step generator advanced configuration
    The step generator in EMC2 is very flexible. It has defaults that work with most drives, but if you have special requirements, you can customize its output. Among other things, you can configure the minimum length of step pulses, the minimum space between step pulses, the minimum time between direction change and the start of the next step, and the minimum time the direction output is held steady after the step completes.
    The complete stepgen documenation is here: http://www.linuxcnc.org/docs/2.1/htm...stepgen.9.html
    Aug 2007
    7
    EMC2 step generator: advanced configuration
  1. EMC2 Axis Manual Tool Change
    By tomdoyle in forum LinuxCNC (formerly EMC2)
    Last Post: 08-09-2010, 02:46 PM
  2. Replies: 2
    Last Post: 02-27-2007, 05:46 PM
  3. A axis direction change?
    By nervis1 in forum Fadal
    Last Post: 10-27-2006, 04:49 PM
  4. How cutting direction change
    By freesman in forum BobCad-Cam
    Last Post: 07-28-2006, 09:02 PM
  5. step in what direction
    By craftech in forum Stepper Motors / Drives
    Last Post: 10-13-2004, 11:45 AM
