586,106 active members*
2,987 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > unable to manually select Tool with number > 99
    Aug 2020
    131
    I'm currently about to switch my CNC over to TNG.
    While testing out the software I noticed that I'm not able to manually switch to tools with a tool number lager than 99.
    According to the manual tool number between 1 and 255 are possible. However in the Menu "Machine/Tools/Change" only tools up to 99 are listed.
    Changing with gcode & M6 is working correctly and the correct text is shown in the Popup Text Box.
    Is this by design or is this a bug in the GUI?
    I'm currently running SW 2020.07.31
    best Regards
    Klaus
    Mar 2017
    1312
    Re: unable to manually select Tool with number > 99
    999 tools are possible. Manual needs to be updated.
    However in tool change and tool select menu only numbers 1-99 are displayed. This is by design.
    Aug 2020
    131
    Thanks for the info.
    Nice to know that the limit was raised.
  1. Manually release tool holder on Torq Cut 22
    By hax0red in forum Bridgeport / Hardinge Mills
    Last Post: 12-13-2016, 08:08 PM
  2. TO CHANGE AN ATC SPINDLE TOOL MANUALLY
    By tdoz in forum Spindles / VFD
    Last Post: 01-20-2016, 09:07 AM
  3. Unable to edit tool.tbl
    By johngalt47 in forum LinuxCNC (formerly EMC2)
    Last Post: 04-07-2014, 05:14 PM
  4. How to change tool Manually?
    By happytriger2000 in forum Mach Software (ArtSoft software)
    Last Post: 08-01-2013, 08:55 PM
  5. Setting tool Z manually?
    By mafitch7479 in forum HURCO
    Last Post: 08-05-2011, 10:24 PM
