586,094 active members*
3,807 visitors online*
    Dec 2014
    connector wires on NEMA 23
    I built a KRMx02 about 5 years ago. I had finally got the damn thing working in jog mode when my (OLD OLD OLD) computer began to seize up when in MACH3... probably from dust and general inattention. I intend to try to move to a RaspberryPI controller. Its cheap enough that if I can't no big deal.
    My NEMA 23 motors (4: y, 2x, Z) are connected to the current controller by what appears to be the old type video connector. Is this a special arrangement of the CNC RouterParts engines? Can I simply cut the connector and use the wires within?
    Nov 2012
    1267
    Re: connector wires on NEMA 23
    It's a D-Sub type connector. In the past hundred years or so, those connectors have been used for all kinds of purposes in all kinds of electronic equipment - including, as you can see, some CNC machines. You can definitely cut the connector off, or you can buy a matching connector for it (if you want to be able to disconnect the motor quickly).
    Dec 2014
    Thank you for the handholding. I looked up the company I bought it from, asked the question and got the response: https://www.cncrouterparts.com/5a-bu...tor-p-296.html
    I'm a little freaked out by what I'm trying.
    1227
    Please document the change to Raspberry Pi as I believe a lot of us would like to know how it goes.A small and cheap controller might free up some useful workshop space in addition to consuming very little power.
  1. Wiring advice Nema 34 12 n.m motor, 8' wires?
    By disneytoy2 in forum Stepper Motors / Drives
    Last Post: 01-05-2019, 10:29 PM
  2. OP connector sanyo denki servo PV drive - looking for connector
    By gm276 in forum Want To Buy...Need help!
    Last Post: 12-15-2018, 07:39 PM
  3. Nema 23 wires
    By Gallchobhair in forum Avid CNC
    Last Post: 04-06-2014, 12:26 PM
  4. Remove Pins in Connector - Repair broken wires
    By ontariocnc in forum Maintenance DIY Discussion
    Last Post: 05-04-2012, 06:35 AM
  5. autopsy of a 8 wires nema 23 stepper motor
    By AlainB in forum Stepper Motors / Drives
    Last Post: 01-21-2008, 09:06 AM
