586,283 active members*
3,886 visitors online*
    Dec 2006
    310
    Belt and Chain Tension
    Dear Experts
    As u r aware, in case of machining centers, it takes lot of time to open the covers to check belt and chain tension say in case of ATC Magazine & restore
    Was wondering if there is any other better way of doing this at less time
    Kindly suggest
    Regards
    Jun 2015
    4154
    Re: Belt and Chain Tension
    hy rishikesh some panels arround here have been removed from the machines, or modified in order to put them fast on / take them down fast ( by leaving the screws where they are ), allowing easier acces to lathe spindle & tailstock, mill spindle belts & atc, etc
    pls check modification in attachment; sorry for the rough sketch / kindly
    Dec 2006
    310
    Thanks for your prompt response
  1. Mv 35/40 spindle belt tension
    By fordman300 in forum Uncategorised MetalWorking Machines
    Last Post: 05-23-2012, 02:40 PM
  2. taig mill belt tension
    By zli in forum Taig Mills / Lathes
    Last Post: 07-06-2010, 12:16 AM
  3. at5 25 wide timing belt tension?
    By DanOSB in forum Linear and Rotary Motion
    Last Post: 09-27-2009, 05:45 PM
  4. Belt Tension Options??
    By flash319 in forum DIY CNC Router Table Machines
    Last Post: 09-19-2007, 08:06 PM
  5. Belt Tension Adjuster Design
    By mxtras in forum Mechanical Calculations/Engineering Design
    Last Post: 05-16-2005, 04:33 PM
