586,080 active members*
3,706 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Integrex 100 / Mazatrol Fusion 640mt - Alarm 22 Feedback System Malfunction
    Jul 2005
    46
    Hello. I’m trying to power up / home an Integrex 100 that’s been sitting a few months. After the system boots, the following alarm appears:
    “22 Feedback System Malfunction (5,0,&0025)”
    According to the manual for Alarm 22 ( , , 25):
    Cause This alarm implies decreases in the voltage of the backup battery for the absolute position data detection circuit of the control card.
    Action Re-homing is required since the absolute position data may have been lost. Replace the battery.
    Although, the machine is dead in the water with this alarm displaying. It will not home, it will not move/jog, it will not clear.
    Any suggestions on next steps to take? (besides replacing a possibly dead battery) Thanks in advance!
    Nov 2016
    Re: Integrex 100 / Mazatrol Fusion 640mt - Alarm 22 Feedback System Malfunction
    I have an integrex 200sy that has this problem on the x axis. The encoder on the servo motor has a little bit of moisture inside it, so when the machine starts up the disk is fogged up and it can't tell whats happening. If you watch the screen, the numbers for the axis that is making trouble change and the motor is not moving. If I turn the ball screw with it Estopped and powered on it will clear up. Make sure that you don't go inside the machine with the power on. Mine will get a new encoder soon. It could be a bad encoder, bad drive, or bad encoder wire but I have seen two that had moisture.
  1. Mazak quick turn nexus 250 alarm 22 Feedback system malfunction
    By phanvinh031092 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-08-2023, 11:39 AM
  2. Fusion 640mt integrex 300y parameter list
    By Augiebaez04 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-08-2020, 04:01 PM
  3. alarm 22 feedback system malfunction (1,0,&0021) after initializing MAZAK
    By kimalpena in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-01-2018, 01:16 AM
  4. ALARM # 22 FEEDBACK SYSTEM MALFUNCTION (1,0,&0043)
    By epordonez in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-15-2013, 05:20 PM
  5. Integrex with Mazatrol 640MT
    By Patrickcrossan in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-12-2012, 02:07 PM
