586,121 active members*
3,546 visitors online*
IndustryArena Forum > CAM Software > Postprocessor for CAM > Morbidelli 1991 U26 Tria Post
    May 2014
    9
    I am having trouble just creating a basic post for the morbidelli u26. Its files are the .pgm I understand how to convert them problem is the post processor I use doesnt make the programs correctly. I have attached a simple 10 inch by 10 inch work piece with 5 inch circle cut in the middle as of how I would write it on the machine. Any one able to make a simple post that can do this exact same thing without adding all the other stuff to a program
    H is the header
    DX is max length DY is max width and DZ is max thickness
    g0 starts router
    g1 moves to next point
    g2 clockwise arc
    g3 counter-clockwise arc
    uses an I and a J to calculate the arc
    v is the feed rate
    s is the spindle speed
    t is the tool
    AB is the field its ran on
    DEF is the tool data stored on the machine
    this machine has a set zero for x and y top left corner is always 0,0 or vice vs. for a mirror on other field DC (top right corner)
    does not need any rapid traverse codes its built into the machine basically when a program comes to an end it stops and basically just moves the z back to a safe z but no special code for that doesnt need any special commands for safe z's
    Any help would be awesome looks like it should be simple as compared to some of the other posts.
    May 2014
    9
    Re: Morbidelli 1991 U26 Tria Post
    anyone have a program that will convert the xxl file or txt file to .pgm I keep getting unknown line 1
    Nov 2020
    I am looking for the same... Please share, thanks.
    https://www.youtube.com/watch?v=73vCldoRh1Q
    Alphacam post processor - https://www.cnc.info.pl/alphacam-f118.html
    For Tria 6000/4000 you cannot put "=" in code
    and spindle speed "S" written as S16, not S16000
    example
    incorrect notation
    H DX = 10.0000 DY = 10.0000 DZ = 0.7500 -AB /DEF
    C1
    G0 X = 5.0000 Y = 5.0000 Z = 0.7500 V2 S16000 T44
    G1 Y = 2.5000 V2
    G2 X = 5.0000 Y = 2.5000 I = 5.0000 J = 5.0000
    correct notation
    H DX10.0000 DY10.0000 DZ0.7500 -AB /DEF
    C1
    G0 X5.0000 Y5.0000 Z0.7500 V2 S16 T44
    G1 Y2.5000 V2
    G2 X5.0000 Y2.5000 I5.0000 J5.0000
    otherwise, the conversion program "CNVRT.exe" will report an error
  1. Tria 7500 for Morbidelli Author 503
    By stoned in forum Controller & Computer Solutions
    Last Post: 03-28-2024, 07:58 PM
  2. morbidelli 504 tria 7500
    By rprman1 in forum Commercial CNC Wood Routers
    Last Post: 08-09-2023, 07:03 AM
  3. Morbidelli 502 Tria 6000 PLC
    By matt_sheehy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-29-2020, 11:37 PM
  4. Morbidelli U26 Tria 6000
    By jon0605 in forum CNC Machining Centers
    Last Post: 01-02-2015, 06:20 PM
