586,060 active members*
4,160 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > System Variable - Calling Program Number?
Results 1 to 7 of 7
    Sep 2019
    6
    Cool System Variable - Calling Program Number?
    CONTROL: FANUC Oi-F / Mill
    When working with a series of nested operations is there a way to return the o-number of the calling program at each level.
    O1111 (MAIN);
    M98 P2222;
    M30;
    O2222 (NESTED1);
    #500 = ##### (??? #4000 Assigns the MAIN op number, but that doesn't work for all cases, see below);
    M98 P3333;
    M99;
    O3333 (NESTED2);
    #501 = ##### (??? How can one assign 2222 to #501 here?);
    M98 P4444;
    M99;
    O4444 (NESTED3);
    #502 = ##### (??? How can one assign 3333 to #502 here?);
    M98 P5555;
    M99;
    And so on...
    Thank you all in advance.
    Feb 2011
    353
    Re: System Variable - Calling Program Number?
    There is also a limit to how many nesting levels that can be done
    There isn't enough information on what you really want. The M98 P xxxx will send it to the program and the m99 will return it to the line after the m98pxxxx call
    What is the use of the #500 ect. in your program. All your example does is record the program number and doesn't describe what you want to do with it
    #501
    #502 ect.
    O1111 (MAIN);
    M98 P2222;(Goto n2222)
    M30;
    N2222
    M98 P3333 (goto3333
    M99 (return to the line after M98 P2222 in the calling program )
    N3333
    M98P4444(return to the line after M98 P3333
    M99
    N4444
    M98P5555(return to the line after M98 P4444
    m99
    Sep 2019
    6
    The code shown is a simplified example. #500's are place holders.
    Is there a system variable that stores the calling programs' O-Number?
    We are needing to write 1111 too #500, 2222 too #501, and 3333 too #502
    We can view the call stack on the Screen Display how do we reference 1 level up?
    PURPOSE: A subprogram will terminate if not called by a specific parent.
    Feb 2011
    353
    this was on the forum from mike xyz on 6/28/10
    Variable #4115 is the last O number read by the control so it contains the current program number.
    Sep 2019
    6
    So, One could add two lines to each calling program... one to store #4115 and then one to clear the stored data.
    O1111
    (PARENT PROGRAM)
    #500 = #4115(IN LEADING SAFETY BLOCKS)
    #500 = #0 (IN TRAILING SAFETY BLOCKS)
    O7777(DEPENDENT CHILD PROGRAM)
    IF [#500 NE #1111] THAN #3000=1(*ERROR* - INVALID PARENT - SEE PRGMR)
    This won't work, if the error is raised #500 won't be cleared...
    Feb 2011
    353
    # 100's clears on reset #500's don't clear on reset
    Sep 2019
    6
    Quote Originally Posted by rcs60 View Post
    ^^^What do you mean by reset? Power Cycle? M30? M2?
    Perhaps with unique parameter settings this is true, however on our controls,
    and all other FANUC machines I have worked on, #100's are only cleared when control is Powered Off and On.
    This is basic Macro-B knowledge. I don't need a review or an argument.
    A better question is, What System Varibles are related to the call stack?
