586,082 active members*
3,772 visitors online*
IndustryArena Forum > Community Club House > Paint that oil will not affect ?
Results 1 to 15 of 15
    Apr 2003
    1873
    Looking for experienced advice here, I have a transmission housing that is made of aluminum, I want to seal the inside with paint, any one know of what type to use so the lube will not affect it ? While not automotive it does use standard differential lube. I glass blasted the interior so it could be dye checked for cracks and while I did clean it I do not want any of the media working it's way out and trashing the bearings or gears.
    Ken
    Probably some type of epoxy paint.
    927
    Ken,
    We used to paint the lifter galleys of our race engines with a type of paint to get the oil to slide back into the pan faster and not pick up as much heat. And to "trap" anything after we had machined the lifter bores and oil return holes and such.
    It was a rust red color. But with old age and time, the name of the product slips my mind. (what's left of it.) I think it was a Rust-O-Lem product.
    You might ask around at the local hot rod shop or even do search on the web for it. Maybe "engine lifter galley paint".
    There are probably better products now as that was some 25 years ago.
    Apr 2003
    1873
    Ger21, not sure on the epoxy, I believe it would hold up to the lube though, Epoxy makes me think thick an flaky.
    I have tried the search thing Ward but nothing comes up as of yet, may call Jegs or Summit tomorrow, I am thinking some sort of chromate.
    Ken
    Jan 2004
    353
    WMS: From memory there was another product "Glyptal"
    I used it for lifter galleys and internals a long while back also.
    I think it was designed for electric motors (this is really giving the brain a workout here)
    This is from back when I was a kid playing with Big Block Chevs and a tip I picked up from a HP book.
    927
    Glyptal.
    Thanks IJ,
    That was it.
    Here is a link Ken.
    http://www.eastwoodco.com/shopping/p...ProductID=2298
    Apr 2003
    1873
    Thanks IJ and Ward.
    Ken
    927
    No thank you Ken and IJ.
    That was a trip back in time, for a minute any way.
    Well... back to the present.
    Feb 2004
    2337
    How about using silicon. Not much touches that. It also has good sealing capabilities and withstands high temperatues. It also is flexible.
    Just a thinking out of the square idea.
    No Ken I havnt read the pdf yet .
    Being outside the square !!!
    Jan 2004
    353
    Just broke out the abacus and that was 25 years ago for me !!
    WOW where did that 1/4 of a centaury go?
    "Rustoleum" was mentioned in my book but I could never find it for sale here in Australia at the time.
    Mar 2004
    190
    Hey, lot of thinks have happened..
    Star Wars saga, the first PC, the Columbia first reentry, the Dolly sheep, Michael Jackson raise and fall, U2 Joshua Tree album, Mandela's freedom, 500 years of Columbus discovery, Enya, seven Olympics games, Exxon Valdez disaster, Nirvana, Malvinas war, Viagra, Internet and dot com bubble, human genoma deciphered, and I am sure that I forgot something..
    ...ahm yep of course! CNCZone
    Fer
    Apr 2003
    416
    Ken,
    We have aluminum parts painted that go into helicopter transmissions. The specification calls for a Epoxy Polyamide Primer (Mil-P-23377). If used on an interior surface, it does not need a topcoat.
    Bill
    Apr 2003
    1873
    Thanks Bill,
    I will look into that, what was removed was not epoxy primer, but that may well be what is used today, I will call the manufacturer and see what they have to say.
    Ger21, looks like you may have hit the nail on the head with your suggestion of some type of epoxy.
    As long as you get a good bond (a little unsure about the aluminum, may need to chemically etch it ?) , I think a good epoxy paint would be extremely durable.
    Apr 2003
    416
    The surface preperation consists of
    1. degrease (Vapor or solvent)
    2. Soap scrub
    3. Rinse
    4. Dry
  1. Paint in carving/letters
    By Dman in forum DIY CNC Router Table Machines
    Last Post: 03-19-2012, 11:39 PM
  2. Coolant eating my paint.
    By nervis1 in forum Uncategorised MetalWorking Machines
    Last Post: 12-05-2007, 10:27 PM
  3. Panel Paint Help Needed
    By Al_The_Man in forum Uncategorised MetalWorking Machines
    Last Post: 09-09-2004, 12:41 AM
  4. AMSOIL ever heard of this Oil what do you think about it?
    By WallCrawler in forum Community Club House
    Last Post: 06-04-2004, 10:09 PM
  5. Can a wood router make paint stencils?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 05-10-2004, 06:46 AM
