586,103 active members*
3,318 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Looking for pictures of Syil x5, x6, or x7 electrical panel
    I recently picked up a used Syil X6 with a gutted electrical cabinet and I am looking for pictures of the inside of the electrical panel so I can see how Syil laid out the original cabinet. Thanks for your help.
    Oct 2008
    2100
    They use different controls on some of the same machines, so a photo of the layout might only at best be generically helpful.
    Realistically if you're going to set up your own controls for it you just need to set up your own control layout for it.
    Once you figure out all the controls you're going to use set them on the table and look at them and look at the cabinet and decide where you would put them to make it the easiest to wire and route wiring.
    Bob La Londe
    http://www.YumaBassMan.com
    Re: Looking for pictures of Syil x5, x6, or x7 electrical panel
    Thanks for the reply, that is exactly what I ended up doing. Got it all wired and everything working except I am in need of a replace LCD screen. I have contacted Syil about a replacement but have yet to hear back from them.
    May 2022
    Hi!
    I am having the same issue, I can figure out what is what in the back of my machine.
    Could you please take a picture so that I can see what is wrong with mine?
  1. Electrical panel wiring for hybrid steppers
    By MattCCabs in forum CNC Machine Related Electronics
    Last Post: 05-15-2020, 06:06 AM
  2. Electrical Panel
    By kolias in forum Open Source CNC Machine Designs
    Last Post: 09-06-2013, 12:27 AM
  3. Replies: 3
    Last Post: 09-27-2011, 03:12 AM
  4. some pictures of syil machine compare
    By syil in forum News Announcements
    Last Post: 05-13-2010, 12:51 PM
  5. Electrical Panel & Router Wiring Diagrams
    By Santa Fe Al in forum CNC Machine Related Electronics
    Last Post: 03-26-2009, 01:51 AM
