588,201 active members*
5,109 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc O-T series display wrong data on startup
Page 1 of 2 12
Results 1 to 20 of 21
    Jul 2016
    12
    Hello Dear,
    We have a Fanuc 0-t series controller. Recently, there is a problem with CNC loading. After the switch on the machine, there is wrong data on the screen.
    I have checked the CRT monitor and it's ok.
    Please see the attached file.
    best regards
    Attached Thumbnails Attached Thumbnails 20201021_115143.jpg   20201021_115244.jpg
    Re: Fanuc O-T series display wrong data on startup
    You may need to reload the Parameters.
    If that doesnt help it could be either the
    Graphics Memory card (CCX4) or the
    Machine Memory card (CCX5)
    Best wishes, TJ
    Jul 2016
    12
    Hi TJ,
    Thanks for your reply.
    Actually, I solved the problem. But now there is a new problem. All parameters and parameters have removed.
    I emailed MTB company but they don't support this machine anymore.
    Do you know any other way to reload the programs and parameters?
    Also there is a Macro Cassette B on the main printed circuit board and maybe the backup file in it.
    Do you have any information on how load program from the Memory cassette B?
    And also may you have access the backup of this machine?
    Machine no: Ge Fong, Swiss type lathe, GNT-1712
    controller: Fanuc o-t series
    Best regards
    Quote Originally Posted by karakas61 View Post
    Hi TJ,
    Best regards
    I am a CNC "board level repair" depot so I am not all that familiar with operation and programing
    but the Manuals will list all the Generac Parameters to get it running.
    There should be a Parameter list that came with the Machine also.
    Sometimes in a pocket on the inside of the Control door on some machines.
    The Part Programs I am not sure about the Cassette. Send your inquirey to...
    https://us.mitsubishielectric.com/fa/en/support
    Wishing you good luck, TJ.
    Apr 2009
    1383
    I do not see the display photo.
    The cassette has nothing to do with the parameters or part programs.
    Do you have any backup files?
    Jul 2016
    12
    I found the backup parameters and I entered them manually and all alarms have solved.
    But now the CNC got stuck at MDI mode and can't change mode by the selector. Because of this problem, I couldn't be connected by serial connection and had to set parameters manually.
    What's your idea about changing the mode problem? Is there any PMC flag in the ladder program associated with the mode selector?
    On the diagnostic page when change the mode selector, X000 bits changed.
    best regards
    Jul 2016
    12
    Quote Originally Posted by memoryman View Post
    Thanks for your reply, Dear,
    best regards
    Apr 2009
    1383
    The mode defaulted to mdi because you likely lost the diagnostics (pmc params) and will have to reenter them .
    Jul 2016
    12
    DGN backup number is from N10300 to N10499 but there are not these numbers neither in parameters nor in diagnostics. So how to enter DGN parameters?
    I uploaded the backup file. Please see the attached file.
    Jul 2016
    12
    I found that the diagnostics parameters are from D0300 to D0499. But it's impossible to enter data to these parameters.
    I tested with PWE=1 and PWE=0 but it didn't work. Could you please suggest your solution?
    Apr 2009
    1383
    Have the 900 series parameters been loaded?
    You load these just like you would the parameters. You just have to be on the DGN page. Fanuc adds the N10 in front of the DGN parameters. So N10300 is the same as 300. The DGN parameters are used by the ladder so if you can't change a value it's because the ladder is writing to it.
    Jul 2016
    12
    Yes, I have and also checked again, all of them are correct according to the backup file.
    Basically, is it possible to initial the DGN parameters?
    Jul 2016
    12
    Quote Originally Posted by drdos View Post
    Thank you for you reply.
    Which DGN parameters are modifiable by the user? What is the DGN backup (D0300-D0499) used for?
    My basic problem is that the machine got stuck in MDI mode. However, when changing the mode selector, the related Ladder output (like R555.3) is active and it is indicated on the screen in DGN parameters (x0000-x0004).
    D0300-D0499 are MTB defined. These are used by the PMC ladder logic. They are typically timers and counters but can be settings for different machine's options. You can enter the D0300-D0499 by hand. Some won't let you change don't worry about those. Be sure to cycle power after you entered them.
    Jul 2016
    12
    It is impossible to enter the DGN parameters. (none of them).
    Could you please guide me if you know a way to enter them?
    MDI mode and PWE is on?
    Jul 2016
    12
    Yes, PWE=1 and Mode is MDI.
    Try changing parameter 19 bit 7. That is the bit on the far left side
    Oct 2009
    297
    Push the Emg button. Also, PWE must be ON. Sometimes it helps if you turn the program edit key to "ON". Would you take a photo of the DIAGNOSTICS SCREEN?
    Regards
    Alex Fanuc
Page 1 of 2 12
