586,036 active members*
3,817 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > What Back Turn Tools do you prefer?
    Oct 2016
    8
    We run a number of Nomura Swiss machines from 13mm to 25mm and have always used primarily the SCHR style of Iscar back turn tools on most of them. We use Mitsubishi for a deep cut back turn tool. 90% of our parts are 303SS. I was interested in what back turn tools most people use and why? Some important factors for us are:
    1. Insert availability in the US
    2. Performance in 303SS
    3. Life of the insert
    4. Cost of the insert per corner (the Iscar is a double ended insert)
    5. Width of insert for minimum loss of material due to width of back turn when turning to end of part and extending cut for width of part off tool.
    Any help would be appreciated - we are self-taught and can certainly benefit from someone with more experience. Thanks for any input.
    Feb 2011
    353
    Re: What Back Turn Tools do you prefer?
    where i work we us utilis multidex 3000 there is a good variety of inserts and grades and the inserts have their on location pocket that if the whole end of the insert breaks you can still us the other side with no problems
    the 1600 version looks about the same as the iscar ones
  1. can i front/back turn in one Turning project?
    By cryptopsy in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-23-2018, 02:47 PM
  2. Setting drills, ID tools and back working/end working tools
    By jonathan2jones in forum CNC Swiss Screw Machines
    Last Post: 04-22-2017, 01:11 AM
  3. Replies: 0
    Last Post: 04-01-2016, 07:52 PM
  4. Any favorite Back Bore tools?
    By ghyman in forum CNC Tooling
    Last Post: 09-29-2014, 08:45 PM
  5. turned high speed off and can't turn it back on.
    By mishikwest in forum Haas Mills
    Last Post: 03-31-2010, 05:52 PM
