586,108 active members*
3,117 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > 94 Cadet LNC8 program loading
    Sep 2016
    25
    Hey guys. I have a 94 LNC8 That I just got. I am learning the control and CNC lathe operation and programming. I am a pretty decent with Haas mill as far as cam and making parts. My question is what is the best way to load programs in to an rs232 setup like this older lathe? I have not purchased anything yet, so I am not opposed to networking it. I was hoping to maybe get a setup to where I could either do usb or usb from a laptop cabled. I understand there is some dnc software that could be required. I would love to hear thoughts on the cleanest and simplest way to load posts in this old girl. Assume I know nothing. I appreciate the help.
    Apr 2009
    1262
    Re: 94 Cadet LNC8 program loading
    I think that machine has the floppy drive on it? It can use both DOS and Okuma formatted floppies. That will be the easiest way. Copy your program to the DOS disk as a text file then:
    MSDOS>PIP>COPY>FD0:ABC.TXT,MD1:ABC.MIN
    That should rename it as it comes in from the floppy to Main Machine memory.
    Then go to Auto and program select it. Or go to Edit and edit it to see how it looks.
    Once your used to the machine revisit the RS232 method. There’s several posts on here about that.
    Best regards,
    Experience is what you get just after you needed it.
    Sep 2016
    25
    Thanks for the info. I actually purchased a Micro DNC2 unit and that thing works amazing. I am going to get some info together and crate a post on what I was up against and how I made this thing work for little money.
  1. Replies: 2
    Last Post: 04-08-2021, 02:14 PM
  2. Okuma Cadet LNC8 Alarm
    By 3DDonn in forum Okuma
    Last Post: 08-21-2013, 05:15 PM
  3. Setting program zero cadet LNC-8 OSP5020L
    By brandonzp in forum Okuma
    Last Post: 11-05-2012, 11:49 PM
  4. Okuma Cadet LNC8-VAC Unit overheating
    Last Post: 09-13-2012, 05:17 PM
  5. Need help loading program from usb
    By hankster in forum Haas Mills
    Last Post: 07-29-2009, 11:08 PM
