586,655 active members*
4,271 visitors online*
    Mar 2016
    46
    LEARNING MODE
    2 simple questions:
    1. Can a stepper driver run a servo motor.
    2. Can a servomotor run without an encoder.
    Dec 2013
    5717
    Re: LEARNING MODE
    1) No
    2) No, assuming you want positioning.
    By definition a servo has some feedback device, could be a tach in the case of older brushed DC motors & drives or an encoder or resolver in the case of modern AC servos. It is possible to use Hall sensors that feed back to the drive for commutation in BLDC motors.
    Jim Dawson
    Sandy, Oregon, USA
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. vfd will work in demo mode but not in real mode
    By sgaugetrains in forum UCCNC Control Software
    Last Post: 12-06-2019, 01:29 AM
  3. Step Mode and Continius Mode exchanged
    By iron_aro in forum Mach Software (ArtSoft software)
    Last Post: 06-04-2014, 05:42 PM
  4. Bridgeport Interact 2 -- tachometer mode vs. voltage mode?
    By ichudov in forum Bridgeport / Hardinge Mills
    Last Post: 06-28-2010, 07:24 PM
  5. spline mode nurbs mode
    By cooltool in forum CamSoft Products
    Last Post: 03-10-2009, 08:03 AM
