587,436 active members*
3,490 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > UC300ETH + UB1 or AXBB-E which is better?
    Dec 2005
    141
    So I have an X2 that I have had for years and I now want to finish the CNC conversation. My plan is to use hoss plans and nema 23 closed loop steppers. Down the road I might want to add coolant and other goodies so I am looking to have some expansion ability. Which solution would you say is better?
    UC300ETH + UB1 + UCCNC Software Cost would be $365
    or
    AXBB-E + UCSB for expansion + software cost would be $317
    I think UB1 would be overkill for this machine seeing that down the road I am thinking about getting a G0704 as a second machine, but for the price difference of $48 difference... not sure if there are other pros and cons to the 2 different options.
    Mike
    Re: UC300ETH + UB1 or AXBB-E which is better?
    I have a UC300eth-5lpt plus a C10. I don't remember what any of it cost (thankfully) and the AXBB-E didn't exist at the time of purchase, but the setup has been very good. It's better than my ESS was.
    I use a MX3660 and a G540 to control 4 axis (one is the ATC). I use those BOB's on both of those units plus the C10's.
    There's more than one way to skin a cat, as you well know. Find the items the give you the feature you want at the price point you are comfortable with.
    They are basically the same, with the UC300ETH just having more inputs and outputs.
  1. axbb-e with Huanyang VFD
    By fandtm666 in forum Spindles / VFD
    Last Post: 01-09-2024, 06:38 PM
  2. New build using AXBB-e and huanyang vfd
    By Chmexdf5633 in forum Spindles / VFD
    Last Post: 04-14-2020, 01:42 AM
  3. Its Aliveeeee my AXBB-E is working
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 01-31-2020, 01:39 AM
  4. my AXBB-E and UCSB are on the way, small annoyance is anyone using axbb with mach3?
    Last Post: 05-17-2019, 03:50 AM
  5. New AXBB controller
    By ger21 in forum UCCNC Control Software
    Last Post: 03-20-2019, 11:55 PM
