586,075 active members*
4,114 visitors online*
    Jul 2009
    28
    Trumpf L3030 Acceration Issue
    Our 20 year old laser has done lots of cutting and its getting tired. I want to cut the acceleration down a bit as it really jerks when it goes to move and covers have come loose in the past. Thought it would be easier on the old girl if we cut the acceleration down. We had a trumpf brake that was really jerky and sometimes acted up. I went into the parameters on the brake cut the acceleration down a bit and it really smoothed things out. It was pretty obvious how to set acceleration on the brake but when i go into the laser it is not clear. If anyone knows how I would really appreciate hearing.
    Geoff
    Jul 2013
    10
    Re: Trumpf L3030 Acceration Issue
    If its a newer trumpf ....TC_DYNAMIC_LEVEL(1) (-1) is better cut,,, less acceleration (0) is trumpf standard (1) is user programmable
    This must precede it in the header TC_USERDYN(1.2,5.0) ( that is factory setting you can dial down to 1.0, 4.5 maybe if need be)
    it is my belief that changing the bearings and keeping the machine properly lubed you should be able to run with factory presets)
  1. trumpf trulaser l3030 fiber
    By Nielske93 in forum Fiber Laser Cutting Topics
    Last Post: 05-06-2021, 03:41 PM
  2. TRUMPF L3030 - NCU error - MN_IPO_PARAM_NAME_TAB
    By bencaha in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-28-2020, 08:13 AM
  3. Trumpf L3030 4kW nitrogen high consumption
    By Morderesh in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-05-2019, 07:10 AM
  4. Engraving Settigns for Trumpf L3030 TFL4000
    By TShook in forum Commercial Laser
    Last Post: 04-30-2018, 07:19 PM
  5. TRUMPF TRUMATIC L3030
    By ratachosis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-13-2010, 07:08 AM
