586,105 active members*
3,360 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > AutoCAD - Subtract Command - need Shave command
Results 1 to 8 of 8
    Jan 2021
    5
    Hello;
    I have a object that I want to shave off to create a contour. I created an ellipse at one end and a rectangle near the other end and Lofted.
    But now I can't figure how to subtract the partial pieces, because when selected, the whole object is selected ?
    See attached image.
    Aug 2008
    406
    Re: AutoCAD - Subtract Command - need Shave command
    Use separate to to make the part several pieces them you can delete what you don't want .Provided the part part you want to delete is left over from a previous subtract operation.
    Mar 2009
    1982
    not sure if I understood correctly "shave and create". Binary difference could help. Just for curiosity if you can send the model file to me I can try to separate desired parts. If part of hatched body should be removed and another part saved, you just cut the model in half and then they are separate - delete one not touching another ...
    Still not sure if I understood correct.
    Jan 2021
    5
    Quote Originally Posted by gabedrummin View Post
    Unfortunately, there are no Subtracted parts as that command removes improperly.
    Attached are 2 more images.
    Aug 2008
    406
    What I would do is Union the the parts together then you have to make another part to subtract it from the main body to get the result you are after.
    Jan 2021
    5
    Thanks for the input. I think what I might try is to create an ultra thin elliptical ring and use that to loft across the object, which might work well to shave the outer edges off, as leaving the ellipse solid served no function.
    Spit the gray piece in two by making a copy and using slice, then use intersection on the one half and union on the other?
    Jan 2021
    5
    I figured it out. It takes 6 steps.
    1. Create an inner ellipse that will shave off exactly what is needed.
    2. Create an outer ellipse that is greater then the object being shaved.
    3. Extrude the inner ellipse beyond the length of the object.
    4. Extrude the outer ellipse just short of the inner ellipse.
    5. Subtract the extruded inner ellipse from the extruded outer ellipse.
    6. Subtract the extruded outer ellipse from the object.
  1. Move command works until velocity command issued
    By madprinter in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-30-2015, 01:06 AM
  2. autocad command box popped up
    By veronicald in forum Community Club House
    Last Post: 12-04-2013, 04:15 AM
  3. AutoCAD text box (command box)
    By Jordtech in forum Autodesk
    Last Post: 10-11-2011, 12:36 AM
  4. G command
    By swatcher in forum Fanuc
    Last Post: 05-27-2008, 11:57 PM
  5. Autocad to cnc -and the "list" command
    By draftingrus in forum G-Code Programing
    Last Post: 04-09-2007, 11:09 AM
