586,113 active members*
3,338 visitors online*
IndustryArena Forum > WoodWorking Machines > Uncategorised WoodWorking Machines > Professionals teach you how to buy cnc wood router
Results 1 to 1 of 1
    Jan 2021
    5
    When choosing Cnc wood router, the following aspects should be considered first:
    1. Convenient clamping, simple fixture structure is also the choice of CNC equipment is a factor to be considered. The choice of horizontal CNC lathe or vertical Cnc wood router will directly affect the structure of the selected fixture and the machining coordinate system, and directly relate to the degree of difficulty of NC programming and the reliability of NC machining.
    2. The working precision of the lathe conforms to the machining precision required by the process.According to the processing accuracy of the parts to choose the lathe, such as low precision requirements of the rough machining process, should choose the low precision lathe, high precision requirements of the finishing process, should choose the high precision lathe.
    3. The dimensions of the main specifications of the Cnc wood router should be adapted to the contour dimensions of the workpiece.Namely, small workpieces should be selected for small size lathe processing, and large workpieces are selected for large size lathe processing, to achieve the reasonable use of equipment.
    4. The power and rigidity of the lathe as well as the range of movement shall correspond to the nature of the process and the most suitable cutting amount.If the rough machining process to remove the blank allowance is large, the cutting allowance is selected large, it requires the lathe to have large power and better stiffness.
    5. The structure of the lathe depends on the size of the lathe and the weight of the workpiece.
    Understand the above content, you can better choose Cnc wood router, more technical problems can consult BCAMCNC technicians.
    More technical and product information please visit the website https://www.bcamcnc.com/
  1. 1224 5 axis Carousel ATC CNC Wood Router New Design for foam wood carving
    By BlueElephantCNC in forum News Announcements
    Last Post: 12-26-2019, 08:56 AM
  2. Teach you how to use China cnc router
    By allencncrouter in forum Videos
    Last Post: 08-28-2018, 02:35 AM
  3. Small CNC Wood Router VS Large CNC Wood Router
    By omnicnc in forum News Announcements
    Last Post: 03-16-2013, 06:25 AM
  4. MANY CNC Professionals needed in SE USA
    By BILL WRIGHT CCR in forum Employment Opportunity
    Last Post: 11-11-2011, 09:22 PM
  5. NNED CNC PROFESSIONALS (MANY)
    Last Post: 10-02-2010, 03:23 AM
