586,717 active members*
3,155 visitors online*
Results 1 to 6 of 6
    Jan 2020
    COLCHESTER TORNADO 80 alarm 1007
    Hello!
    We have COLCHESTER TORNADO 80 with GE-FANUC 21-t
    At each attempt to rotate the spindle gives an alarm 1007 monitoring hardware fault.
    We read about the recovery procedure, but we do not have such a supplementary board.
    We will be grateful if anyone can help.
    Thanks!
    Mar 2020
    6
    Re: COLCHESTER TORNADO 80 alarm 1007
    Hi, If your tornado is equipped in SSM Board, you need to use procedure as bellow
    If, with the link, LK2, in the right hand position, +5A, the push button on the SSM is held down while the main isolator is switched on as described above to delete the Alarm History, but then is
    held longer, the SSM display cycles around the available maximum spindle speed settings
    When the required maximum speed is displayed releasing the push button writes this value to the SSM memory.
    The main isolator must now be switched off and the link restored to its normal position
    Good Luck
    In case SSM failure I can offer to repair it.
    Exclamation Re: COLCHESTER TORNADO 80 alarm 1007
    Quote Originally Posted by AndyM23 View Post
    Good Luck
    Can you please specify what is the main isolator?
    I am facing a problem with my tornado 110 with fanuc 21i-t but whenever the machine boots it gives an emergency stop alarm and then 1001 spindle speed monitoring -no response
    Arrow Re: COLCHESTER TORNADO 80 alarm 1007
    A photo for the error ladder
    May 2016
    526
    Board is located either to the left of main A3 board or alternatively on right hand side panel
    Private message me your email and I will send you procedure
    May 2023
    6
    Hello,
    @AndyM23. You mentioned that you can repair SSM, It seems i have faulty SSM on my colchester tornado 110 but i am not sure. Would you be able to check it out or give me some ideas what to try?
    Best regards
  1. Operating Colchester Tornado A50
    By Kenny Heernaert in forum Colchester Tornado lathes
    Last Post: 11-10-2022, 09:06 PM
  2. colchester tornado 200
    By fazico in forum Questions or Problems
    Last Post: 11-03-2015, 06:38 PM
