603,810 active members*
3,131 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > 304 invalid I,J, OR K in G02 or G03
    Jan 2021
    I'm currently training in CNC Lathe but I'm running into an issue with the arch. I am currently on a Haas Simulator. My instructions were to use IJK but I'm struggling.
    Awbrey P
    Aug 2009
    1573
    Re: 304 invalid I,J, OR K in G02 or G03
    ...try using R for arc center. Read more about it below link
    https://www.haascnc.com/service/code...value=G03.html
    sip-
    The R-value defines the distance from the starting point to the center of the circle. Use a positive R-value for radii of 180 or less, and a negative R-value for radii more than 180.
    Feb 2011
    353
    with out the information on the print it will be hard to give you the correct answer
    if the arc is being cut from .440 in the x axis to a smaller x value then back to the .440 dia.(G2)
    with the z axis starting at -.565 and finishing at -.940 your k value would be k-.1875
    Aug 2009
    1573
    ...sim report when fixed. Followup
    over vs under Newton's Law
    Jan 2021
    Thank you all for the suggestions but we just
    Split the arch into two partials and it worked
  1. Invalid G02 or G03 due to radius
    By GSAM07 in forum Haas Lathes
    Last Post: 01-15-2020, 03:48 PM
  2. invalid I, J, OR K in G02 G03
    By Aschrad in forum Surfcam
    Last Post: 04-06-2019, 12:57 PM
  3. INVALID I, J, K
    By Cshade30 in forum Haas Mills
    Last Post: 03-21-2019, 04:27 PM
  4. Invalid code 241
    By CAMAUTO in forum Haas Mills
    Last Post: 08-06-2014, 03:43 AM
  5. Invalid R in G0
    By yz426four in forum Haas Mills
    Last Post: 09-24-2008, 02:52 PM
