586,108 active members*
3,066 visitors online*
Results 1 to 7 of 7
    May 2015
    35
    Question slow threading
    When I do a mill thread feature, it has a very slow intermittent feed. I set the feed for 25 ipm and it will only do it smoothly at 5 ipm. I am using V33 and sending to M Plus control via pred ed and quatech server. Any ideas? It is an npt thread.
    Aug 2009
    1573
    Re: slow threading
    ... G09 or G08 blending maybe...What machine is Big Bob v33 for?
    May 2015
    35
    Re: slow threading
    Mazak VTC 20 B
    Oct 2006
    73
    Re: slow threading
    Hi Jmooresshop, Have you got this figured out?
    I once consulted for a shop running all Mazaks and they kept throwing errors trying to thread mill. Turns out they ran their machines in IPR mode all of the time so when I shipped them a toolpath in IPM the control freaked out because it couldn't physically move the tool 35 inches per revolution at 2000'ish RPM.
    Maybe exact stop is on?
    Are you DNC'ing from the server? Too slow a baud rate for the tiny lines to thread mill?
    May 2015
    35
    Re: slow threading
    How would I check to see if exact stop is on or off? I am not familiar with that term. Baud rate is as high as I can go. When I do 3D profiles, it feeds fine.
    Oct 2006
    73
    Re: slow threading
    Exact stop mode forces the machine to hit the programmed points dead on before moving to the next point. It causes slow jerky motion on programs with a lot of tiny lines and arcs. G61 turns exact stop on and G64 turns it off. G09 is a non-modal exact stop. If 3D profiles work fine then exact stop is most likely off.
    Sadly I'm not a MAZAK expert. I only have the one experience thread milling on one.
    May 2015
    35
    Re: slow threading
    Thanks for taking the time. I appreciate it.
  1. Replies: 2
    Last Post: 04-11-2019, 05:40 PM
  2. THREADING: How to add threading parameters to the Init file?
    By jeffserv in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-22-2015, 06:50 PM
  3. Replies: 3
    Last Post: 08-08-2014, 04:42 AM
  4. Limit/Home wiring and how slow is slow?
    By Michaelofburien in forum DIY CNC Router Table Machines
    Last Post: 05-24-2013, 07:44 PM
  5. slow tm-1
    By pit202 in forum Haas Mills
    Last Post: 04-18-2006, 08:14 AM
