586,076 active members*
3,669 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > mori seiki mapps msg 501 program edit!!!
    Feb 2020
    7
    Unhappy mori seiki mapps msg 501 program edit!!!
    Hello engineers. PLZ HELP!!!
    We have a Mori Siki nv5000 machine with controller fanuc 18i - mapps msg-501.
    When we want to edit or add a program. system say error "EDITION IMPOSS"
    PANEL key-switch in edit position and screen in edit mode .
    Does anyone have a mapps operation manual or mapps parameters manual?
    Oct 2007
    74
    Re: mori seiki mapps msg 501 program edit!!!
    Are you still having this problem? Do you get any alarm number prior to the message.....ie EXnnnn code before the message?
    Feb 2021
    4
    Hello Antipak,
    Do you have on the controler a button with GOP PARAM ?
    If you have it push it and on the screen there will be a key above PROGRAMM / OFFSET / PARAM MAKRO
    Push the buttom PROGRAMM and the key needs to go OFF.
    Hope I could help.
    Grtz Tom
  1. Mori Seiki ZL-253 program setup
    By MGood in forum Fanuc
    Last Post: 12-18-2021, 08:15 AM
  2. Mori Seiki SL2 damping program
    By Marik1 in forum Mori Seiki lathes
    Last Post: 01-28-2014, 04:34 PM
  3. MAPPS Parameters for a Mori Seiki NL
    By tminnig in forum Fanuc
    Last Post: 09-30-2008, 10:57 PM
  4. Mori Seiki Sub program
    By adaptaflex in forum Fanuc
    Last Post: 06-20-2006, 10:03 AM
  5. Mori Seiki Sub program
    Last Post: 06-19-2006, 02:59 PM
