586,114 active members*
3,398 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > 4140HT Steel Feeds and Speeds
    I am looking for some insight on cutting 4140HT Steel. I am only familiar with cutting 6061 aluminum, so steel is totally new to me. Do you have any speed and feed tips, or any machining tips in general? I will be using mainly 7FL 1/4 and 7FL 1/8 Endmills. Please let me know, thanks!
    Re: 4140HT Steel Feeds and Speeds
    there is a variety of carbide end mills with a variety of cutting conditions, thats assuming your using carbide . There isn't really a one answer fits all
    if the tools your using are of quality then the manufacturer's website should have the recommended sfm for their cutters
    Feb 2012
    41
    Go to G-Wizard Calculator Free Trial Signup 2020 - CNCCookbook: Be A Better CNC'er and sign up for a free 30 day trial of G-Wizard Feed & Speed Calculator. I'm not connected to the company other than being a very satisfied G-Wizard user for the past 10 yrs.
  1. Feeds and speeds for steel
    By upnorth in forum Novakon
    Last Post: 09-17-2020, 03:41 PM
  2. Hardened Steel Speeds/Feeds Sanity Check
    By JJ0704 in forum Milling
    Last Post: 01-11-2020, 01:29 PM
  3. Steel Feeds and Speeds
    By pyropanda5 in forum Tormach Personal CNC Mill
    Last Post: 04-20-2017, 05:21 PM
  4. Speeds and feeds for steel
    By lead-slinger in forum Mechanical Calculations/Engineering Design
    Last Post: 01-28-2012, 06:22 AM
  5. Speeds and Feeds for ASTM A-500 Grade B Steel
    By nfrees114 in forum MetalWork Discussion
    Last Post: 02-26-2010, 05:05 AM
