586,100 active members*
2,713 visitors online*
Results 1 to 10 of 10
    Jul 2003
    1754
    emc2 running a hermes engraver - video.
    Just hooked some parker/compumotor drives to the existing steppers to play.
    http://www.youtube.com/watch?v=dKz81fY1OjY
    I am actually running the optos in the drives directly from the printer port. This is just a mock up to see how it runs. I will do a complete job now that I see it works great.
    This is the controller that came with it. I need to fix it. really burned a mosfet.
    Apr 2005
    1778
    Sam,
    It looks like it runs good.
    Alan
    Jul 2003
    1754
    I think I am going to sell this - it is not really what I need. Fun little toy though.
    Jul 2003
    1754
    dry run of the penguin
    http://www.youtube.com/watch?v=Hdhn_j6PrCw
    sam
    Jul 2003
    1754
    I fixed the original controller that smoked..
    Here it is going thru the homing sequence.
    http://www.youtube.com/watch?v=4JUG1Qz7Xu8
    here are some more picutres
    http://www.electronicsam.com/images/engraver/
    sam
    Apr 2005
    1778
    Sam,
    Does it still use a PC to control it (i.e., does it still run emc2)?
    Alan
    Jul 2003
    1754
    I am using some parker stepper drives (step and direction) run dirctly from the printer port of a 1ghz machine. (old compaq)
    I have not tried the controller (EP control module) that came with it because I have not found the software yet. You still need to use a computer to run the machine. I have the 2 keys (printer port key - dongles) for gravosoft 98 and casmate but not the actuall software. It sort of turns it into a glorified printer.
    If I where to keep it - I wouldn't even use the ep module that came with it. The cable the plugs into the ep module unplugs from each axis under the machine (that is how I have the parker drives hooked in). It had limits and on both end of all but the z axis. very easy to convert to emc2 (or mach if you go that way ) it would give you full 3 axis motion 20"X15"X2.25" as you can see from the videos.
    sam
    Jul 2003
    1754
    couple more videos - cutting circuit board
    http://www.youtube.com/watch?v=Og6V-nS2dig
    450ipm using emc2 doublefreq
    http://www.youtube.com/watch?v=a_OUN...elated&search=
    sam
    Apr 2004
    28
    Would you be interested in letting go of your CASmate Pro dongle? I also am interested in any New Hermes fonts that you are not using and a CASmate manual.
    - George Lawrence Storm
    George Lawrence Storm, Kenmore (Seattle), Washington
    Inventor, Machinist, Macintosh Applications Developer, Videographer
    Jul 2003
    1754
    Sorry - I sold everything on ebay a few months ago..
    sam
    Quote Originally Posted by keencoyote View Post
  1. Hermes Vanguard 7200 Engraving machine
    By samco in forum Engraving Machines
    Last Post: 10-07-2019, 05:49 AM
  2. New Hermes routers
    By Laff Riot in forum CNC Machining Centers
    Last Post: 07-15-2008, 01:34 AM
  3. Need advice regarding a New Hermes IS400 Purchase
    By Spevinator in forum Uncategorised MetalWorking Machines
    Last Post: 06-05-2008, 06:30 AM
  4. Upload your video of you machine running with Mach
    By ynneb in forum Mach Software (ArtSoft software)
    Last Post: 07-10-2007, 11:44 PM
  5. Emc2
    By sdantonio in forum Mach Mill
    Last Post: 02-05-2007, 09:26 PM
