586,119 active members*
3,582 visitors online*
IndustryArena Forum > MetalWorking Machines > Colchester Tornado lathes > FANUC 0T parameters for Colchester CNC350 Live tool (C axis)
    Nov 2016
    12
    Hi
    We have here a quite old (from about 1993) Colchester CNC 350 with FANUC 0T & DUPLOMATIC 12 turret that has also live tool capability at it with the , Lathe has lost its parameters more than a year ago due to low batteries. I have found the standard setting parameters for 2 axis with the help of a member here and the machine machine works flawlessly since back then. The manual of the machine we have it doesn't have the builders parameter inside it, and upon to that, it's not describing the exact hardware of our machine, as this was a one off special order one as we learned! Builder has no data about it as they said due to been special order didn't kept them (?) or archived them!
    Problem is that now the owner wants to run the live tool capability of it, and we have to find how to set it to work as a "third axis" (the machine before loosing its parameters was a 3axis one, with FANUC OT display showing also "C" axis, that it doesn't now).
    Question is how I can set it to work with it? Hardware is
    FANUC 0T controller
    Turret: 12 tools Duplomatic BSV-160 - 12 -24 -110 -50
    Live tool ODT-N16-270/0/20-RM
    Live tool servo amplifier is a FANUC C series A06B-6066-H006 connected at A16B-2200-0360 Axes card M47
    Anyone that can help me?
    Attached Thumbnails Attached Thumbnails 3rd-2.jpg   viber_image_2021-03-22_11-53-45.jpg   viber_image_2021-03-19_13-14-40.jpg   viber_image_2021-03-19_14-37-28.jpg
    Aug 2017
    Hi, I only read the thread title, and not your post. Sorry
    However, I work on 2 Tornado 2axis lathes and if you need me take a screenshot of my machines parameters page tomorow sometime, please reply.
    Thankyou hope I can help
    JOG offset measure z0
