586,113 active members*
3,573 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Torq Cut 22 - Spindle oscillates in M19 Spindle Orient mode
Results 1 to 7 of 7
    Apr 2009
    14
    Hello,
    I have an issue on a new to us 1995 Bridgeport Tor Cut 22 where the spindle oscillates when doing a spindle orient and tool change operation, which can cause some issues with changing tools ( so far only a load pop noise when picking up a new tool)
    If I do an M19 command the spindle locks up and oscillates probably a couple degrees. If a grab the spindle the oscillation will stop. I have added a video of what is happening.
    Looking for some input to see if there are settings I need to change to fix this, or if this is normal for this machine.
    https://youtu.be/LAvx5cKuCm8
    Aug 2008
    7
    Re: Torq Cut 22 - Spindle oscillates in M19 Spindle Orient mode
    Look at the belt that goes from the spindle to the encoder. If it is loose it can cause this problem as it is hunting back and forth to hold the position.
    Apr 2009
    14
    Thank you,
    I gave that a check and tightened it up but it did not resolve the issue.
    I was looking at other threads and think it could be the spindle gain, does that sound like the next step? The actual spindle speed is always a couple RPM less than requested and more as the spindle speed increases if that gives any other hints to the issue.
    Apr 2009
    14
    I think that i have narrowed the problem down to the transmission, I can feel play when manually turning the spindle back and forth that seems about the distance of the oscillation. then checked all the pulleys and they are all tight. I have all the manuals but there isnt anything in there on servicing the transmission. Is there a place to get this information? Thanks
    Mar 2016
    Adjusting parameter #69 worked for me.
    Mar 2016
    Adjusting parameter #69 fixed the oscillating issue but has caused an error with rigid tapping breaking taps.
    Any advice on what to try next?
    Mar 2016
    Solved.
    After Adjusting parameter #69 to fix the oscillating issue, adjust parameter #64 to correct the rigid tapping issue.
  1. Spindle play torq cut 22 with transmission
    By cooperjm in forum Bridgeport / Hardinge Mills
    Last Post: 07-27-2019, 02:33 PM
  2. torq cut spindle, need to run cnc with out spindle running
    By dholby in forum Bridgeport / Hardinge Mills
    Last Post: 10-04-2016, 08:53 PM
  3. Replies: 0
    Last Post: 08-10-2013, 07:28 PM
  4. M19 Spindle Orient
    By ragman in forum Fanuc
    Last Post: 04-01-2008, 11:16 AM
  5. How do I orient spindle after encoder replacement? Torq Cut 22
    By vettespeed in forum Bridgeport / Hardinge Mills
    Last Post: 01-22-2007, 08:39 PM
