586,647 active members*
2,271 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > CITIZEN Machines > Cincom B12 Parameters and PMC Erased. Help if you have a backup
    Lost the parameters and the ladder program for my Cincom b12, and don't have a backup!! Please help if you have a backup of its memory. Should be two or three files... Would be much appreciated! Machine down currently!
    Al
    304
    Re: Cincom B12 Parameters and PMC Erased. Help if you have a backup
    There were multiple versions of the B12. You should state which generation you have and inch or metric. Which control?
    Quote Originally Posted by cogsman1 View Post
    Thank you for responding. Its a 1995 machine, with Fanuc 18B series.
    As for metric or inch, I think it can change unit in its setting.
    Any help would be appreciated, even if the PMC code is not for this particular version, it could help us by giving us ideas for writing the ladder code for it.
    best
    Al
    You didn't loose your ladder. You lost the option bit that states which PMC you have so It won't get displayed till you recover the option parameters. Call Fanuc and see if they have record of that machine. You are going to need the control serial number and if Fanuc has ever worked on that machine and by chance made a backup of that control they may have the backup.
    Quote Originally Posted by drdos View Post
    Thank you for your comment. Are you sure the PMC won't be deleted? We have tried the memory reset, which is through Ctrl + Del + Reset at startup. I was under the impression that it totally erases the parameters and tge ladder.
  1. lost pmc parameters for SMG model V32 mill and backup
    By icetp in forum DIY CNC Router Table Machines
    Last Post: 09-18-2018, 12:47 PM
  2. CNC CINCOM B12-Calibration
    By ENG-CJPC in forum CNC Swiss Screw Machines
    Last Post: 04-30-2016, 09:12 PM
  3. CINCOM B12
    By ENG-CJPC in forum Fanuc
    Last Post: 04-22-2016, 07:51 PM
  4. CITIZEN B12 CINCOM ERROR
    By mackjordan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-12-2014, 06:19 PM
