603,374 active members*
4,402 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > TPA Albatros user level passwords
    Hello, does anyone know what passwords I can use to get a higher user level in TPA Albatros. I need to change something in the tool carousel settings. this does not work at user level. there are 4 levels of user, service, manufacturer and TPA. thank you in advance
    Re: TPA Albatros user level passwords
    Hi Samuel,
    Usually the password is "h", but it depends on the machine manufacturer, what brand is your machine?
    Mar 2023
    Quote Originally Posted by IdanGorali View Post
    Hi Samuel,
    Hi, do you have any more information regarding this?
    I currently have 2 x Felder H80's. I have been informed that I can find the "daily" password if I look hard enough but cant find it anywhere. I have basic access for machine movements etc but looking for a level higher for some easy parameter changes
    I hope you can help
    Aug 2013
    Hello Dear, did you get any chance to have any of the passwords?
    i have felder format4 also, one of the technician said that the passwordi s changed daily, it's as if calculated from date and time or year and month
    please advise
    regards
    Pierre
    Quote Originally Posted by scanlan90 View Post
    I hope you can help
    Mar 2009
    16
    Hello Samuel,
    Did you figure out what the password is for higher user levels?
    I have an Omal machine.
    Thank you
    Feb 2025
    https://www.dropbox.com/scl/fi/05twi6v0y473bjkuctk9y/PswViewer.exe?rlkey=kyqu5ch7t8owb7snhuhzi1ej4&st=3 vnym7lo&dl=0
    This is for my Vitap point2. He also uses Albatros. It works for me.
  1. Albatros / Edicad
    By noodlesgr in forum Uncategorised CAM Discussion
    Last Post: 05-08-2021, 10:24 AM
  2. BIESSE ROVER 13S PASSWORDS FOR NC400 +
    By Trombonel in forum CNC Machining Centers
    Last Post: 04-24-2019, 01:49 AM
  3. Anilam 1100M passwords
    By edbanks in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-01-2014, 10:48 PM
