586,075 active members*
4,086 visitors online*
Page 1 of 2 12
Results 1 to 20 of 29
    Jun 2017
    119
    Planet CNC THC.
    Hi.
    I have now connected and setup my Planet CNC THC.
    But I am getting a code E-1.
    Do you have any info on what this is?
    Mar 2017
    1312
    Re: Planet CNC THC.
    In case of communication failure E-I is shown on the display. Please check the optical cable is properly inserted on both sides and that the sensor device is turned on.
    Jun 2017
    119
    Re: Planet CNC THC.
    Quote Originally Posted by PlanetCNC View Post
    Both are on. The Sensor terminal has the voltage present signal (red).
    I think the error disappeared now.
    I have connected the cables to the input board as below:
    I have setup the THC in the setup tab with input 6 7 8.
    6 THC UP
    7 ARC OK
    8 THC DOWN
    I am trying to get the test function to work but nothing is happening. Have I set it up correctly?
    Jun 2017
    119
    Re: Planet CNC THC.
    Error code is now gone.
    THC is not working as it should.
    It is connected as mentioned above.
    Test function on the THC is not working. It is not moving the Z axis up or down.
    When the machine starts cutting the program starts, pierces moves for 10 mm then the machine just stops. No error codes or anything. The TH I/O lamp lights up. The torch is still burning so I have to press emergency stop to stop it.
    After I unpress emergency stop the machine does is not able to move in any direction. Buttons in software is unpressable. Only emergency stop is able to be pressed/unpressed. I have to restart the program to get it working again.
    Mar 2017
    1312
    Re: Planet CNC THC.
    Don't say that TNG does not work. It works. Your problem is elsewhere.
    Is THC OK signal configured correctly? Does it work is you disable OK signal?
    Jun 2017
    119
    Re: Planet CNC THC.
    Shouldn't I get input signals when I use the test mode for up and down?
    I will try disabling OK signal tomorrow.
    What does the TH light in IO mean?
    Mar 2017
    1312
    Re: Planet CNC THC.
    TH led means that THC is enabled. This is controlled with M54.
    Jun 2017
    119
    Re: Planet CNC THC.
    Ok. That's what I figured.
    I ask again. Shouldn't I get input signals when I use testmode on THC for up and down movement?
    Mar 2017
    1312
    Re: Planet CNC THC.
    Test mode will generate up/down signals but not OK signal.
    If OK signal is required then machine will not move. In test mode disable OK signal.
    Jun 2017
    119
    Re: Planet CNC THC.
    Tried Removing OK signal and check for input up/down. But it didn't change anything.
    Jun 2017
    119
    Re: Planet CNC THC.
    Attached photos of where the inputs are connected.
    I disabled arc OK signal in test mode. Tested with THC to move up and down, still did not get any input signals from THC for up/down motion.
    Mar 2017
    1312
    Re: Planet CNC THC.
    Did you use G-code with M54 for testing?
    Jun 2017
    119
    No.
    You have a button where you can go through different settings on the thc. You have a test mode which simulates up or down motion. Shouldn't this trigger a input signal no matter if m54 is active or not? The inputs should still get a signal?
    Mar 2017
    1312
    Re: Planet CNC THC.
    You falsely assume Z axis will move every time THC sends up/down signal. These are other conditions that must be met. M54 being one of them.
    Jun 2017
    119
    Re: Planet CNC THC.
    Why do I falsely assume that? Isn't that the intended purpose of the THC to send a signal to software to move Z axis up or down if it does not meet the required voltage?
    Can you explain to me the functions of the attached pictures?
    Mar 2017
    1312
    Re: Planet CNC THC.
    For example - if machine does not move in XY direction then plasma will burn a hole, voltage will increase, THC will send "down" signal and your torch will ram into metal.
    Good software prevents this. With M54 you not only enable THC, you can also set min speed and acceleration limitations.
    https://planet-cnc.com/plasma-cnc-an...ith-planetcnc/
    https://planet-cnc.com/wp-content/up...tCNC%20THC.pdf
    Jun 2017
    119
    Re: Planet CNC THC.
    I am asking what the different functions that light up on your THC means.
    What does:
    Sdt on display mean?
    tSt
    AdL
    HYS.
    See the photos I attached earlier.
    Mar 2017
    1312
    Re: Planet CNC THC.
    Sdt - Set delay time from 0.1 to 9.9 sec. Time between Arc OK signal appears and generation of signals up and down is enabled. Factory setting 0.5 s.
    HYS - Hysteresis from 2V to 32V (2 V step). Voltage frame around reference. If arc voltage is higher than Ref + HYS/2 then down signal is generated. If voltage is lower than Ref - HYS/2, up signal is generated. Factory setting 6 V.
    AdL - Ant-dive limit from 50V to 300V. Arc voltage that disables THC. If voltage goes higher than Anti-dive limit all output signals go low. The parameter’s value must be set higher than reference voltage. Factory setting 220V.
    tSt - Test mode. Only available when no arc voltage present! Pressing V or ? button generate output signals. The display indicates direction.
    Mar 2017
    1312
    Re: Planet CNC THC.
    THC user manual
    Attached Files Attached Files
    Jun 2017
    119
    Re: Planet CNC THC.
    THC user manual
    I see you updated the THC Manual. But the date on the first page is the same as the old one. I have one from 26.08.20 that I downloaded when I ordered the THC.
    tSt - Test mode. Only available when no arc voltage present! Pressing V or ? buttongenerate output signals. The display indicates direction.
    When you do this you should get input signal on TNG software on Up/down input?
Page 1 of 2 12
  1. Planet CNC as PNP
    By sairfan1 in forum PlanetCNC
    Last Post: 04-15-2021, 06:04 PM
  2. Replies: 1
    Last Post: 03-07-2021, 11:42 PM
  3. Replies: 1
    Last Post: 11-10-2018, 02:26 AM
  4. Planet CNC without THC Option
    By phamandp in forum PlanetCNC
    Last Post: 08-31-2018, 02:42 PM
  5. Planet CNC
    By yar20 in forum PlanetCNC
    Last Post: 04-26-2018, 05:31 PM
