586,108 active members*
3,112 visitors online*
    Dec 2007
    341
    Need Flywheel turned 11"
    Need to have a fly wheel turned on outside diameter and rim edges two ( ea. ) # 60 surface finish, fly wheel approximate 11 inches casting ,bore HOLE FOR SLIDING FIT FOR .625 SHAFT also put in 1/4 20 setscrew hole for grub screw 15 degree angle thread not necessary.
    The set screw will be centered on the hub either side does not matter , all sizes are as they just clean up to remove casting flash ,clean up center hub, face both end's no clean up on the diameters of center hub.
    Apr 2020
    29
    Re: Need Flywheel turned 11"
    Hi there, do you have 2D and 3D drawings for this? To quote, I need the detailed drawings.
    Dec 2007
    341
    I have a drawing ,all machined surfaces just to clean up and finish cast iron 60 finish
    Dec 2007
    341
    The job has been filled .
    Thank you for to those who replied
  1. Need 3" Dia Part Turned
    By BLKFLD in forum RFQ (Request for Quote)
    Last Post: 10-08-2018, 03:23 PM
  2. Replies: 2
    Last Post: 07-10-2015, 02:18 PM
  3. Batch of turned stainless parts, 85 pieces from 0.5" rod
    By LokiComponents in forum North America RFQ's
    Last Post: 05-26-2015, 12:49 AM
  4. 1.5" Dia Part turned from Steel w/ flats - Qty of 100
    By yantra3d in forum RFQ (Request for Quote)
    Last Post: 05-08-2011, 04:47 AM
  5. RFQ: Turned 304 stainless parts... 5/8" max diameter...
    By InspirationTool in forum Employment Opportunity
    Last Post: 06-22-2007, 09:43 PM
