603,969 active members*
3,188 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Looking at a VF1 and need some advice
Hybrid View
kentdesautel13 Looking at a VF1 and need... 05-24-2021, 05:06 PM
Jim Dawson Re: Looking at a VF1 and need... 05-24-2021, 07:39 PM
kentdesautel13 Re: Looking at a VF1 and need... 05-24-2021, 08:06 PM
    May 2013
    181
    I'm currently running a Haas Super Mini Mill with a 15HP, 10,000 RPM 1,200 IPM
    All of my work is 6061 alum bar stock,
    most of my cutting is done with the RPM running in the 6,000 to 10,000 rpm
    other than some 5/8" ball end mill roughing, most of the my cutting is a 1/4" ball end mill and also lots of detail cutting with a 2mm ball end mill
    I'm looking at a second machine, and I've found a Haas VF-1B VMC, with a 20HP with a 2 speed gear box and 1,000 IPM....
    the the issue is that its max RPM is 7,500
    In your opinion would I be taking a step backwards by going with a machine that has a max of 7,500 RPM?
    The things that I like about the machine is that added X,Y,Z movement, and the 20 spot tool changer, verses what I have on the mini mill.
    Kent
    Dec 2013
    5720
    Re: Looking at a VF1 and need some advice
    Based on your cutting needs, I would say the VF1 would not be a good fit. The only thing you gain is a larger work envelope. Your predominate cutter sizes would dictate a need for higher spindle speeds.
    The Haas TM-2P with a 20 tool changer and 10K RPM spindle might be a better fit. We have a TM-2P with 20 tool changer but only a 6K RPM spindle and wish it was 10K, but we have never run out of spindle HP even at 7.5 HP. Like you our cutting is 90% 6061, with the rest SS. Most of our work is done with 3/8 to 5/8 endmills, with occasional use of 1.5'' face mills.
    Jim Dawson
    Sandy, Oregon, USA
    May 2013
    181
    Thanks Jim....
    That is some great advise... and exactly what I needed...
    I may even consider a Haas Super Mini Mill 2 since my shop floor space is a bit limited..
    Thanks again...
    Kent
  1. 1990 VF1
    By ranchak in forum Haas Mills
    Last Post: 01-31-2011, 07:15 PM
  2. 96 VF1, got trans out, how does it come apart??
    By bob1112 in forum Haas Mills
    Last Post: 10-30-2009, 05:28 AM
  3. 92 Haas vf1
    By sak610 in forum Haas Mills
    Last Post: 07-22-2009, 03:19 PM
  4. Looking to purchase a new Vf1
    By DRD in forum Haas Mills
    Last Post: 09-13-2007, 11:06 PM
  5. Brand new VF1, what to go along with it?
    By Loading in forum Haas Mills
    Last Post: 06-05-2006, 09:06 PM
