Hoping someone can help me out. I’ve got a 1992 VF-0 with a 16 tool carousel that is currently BT40 that I’d like to switch to Cat40.
I’ve searched other threads and haven’t had much luck finding info on the setup I’m using. They talk about swapping the extractor fingers and installing the dog key either on top or bottom of the extractor fingers to accommodate the different sized holders. It’s basically an assembly that consists of the fingers, keys, springs and hardware.
Unfortunately... mine doesn’t use this type of assembly. Instead of “fingers” it is a single piece clip in the shape of a wishbone. The tool holder forces theses fingers to move outwards and then they snap back into place around the tool.
Attachment 464412
I was hoping to just buy new fingers and reassemble but not sure how this type of setup works. Is anyone familiar with this setup and know what may be needed to swap to Cat40? I would assume different clips but unsure if the whole plate needs swapped. Thanks
