603,795 active members*
3,009 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > System files & Parameter on OSP 500 L-G
    Jun 2021
    Hi all,
    My first posting to this board and not good at English so, go easy on me.
    We have a 1993 vintage Okuma LB15 II-M Lathe (M Spindle also have). Operating system is OSP 500 L-G.
    Because the mainboard was ejected while the power was still on.
    The next day on powering up, the bootup sequence stops almost immediately with the following:
    SBP4-B J1.05
    MEMORY TEST OK ! 0000
    LOAD:SYS
    2011 Bubble Memory Read ERROR 00500000 'Parity'
    So we need to reinstall, but we have no disk or system files.
    If you have below files, please give me:
    BINQ8-Q32-B.BBM
    LAU16-VR-W3.PBU
    LSU16-VW-F1.PBU
    LCU06-00-A.PBU
    FOSJ4-07-A.SYS
    LVU16-VA-D2-1.PBU
    LVU16-VE-D-3
    LAA07-AQCH.POL
    LAMJ7-AQCH.POL
    LAC07-AQCH.POL
    LDA01-Q1-B-POL
    LOA04-Q3-G
    Any advise greatly appreciated.
    Regards,
    Alex Vu
    Mar 2009
    1992
    Re: System files & Parameter on OSP 500 L-G
    Are you sure?
    Is the bubble memory still alive?
    Jun 2021
    Yes, I'm sure.
    We checked, it' still ok.
    If you have system disks or files,
    Please help me...
