603,310 active members*
2,315 visitors online*
Results 1 to 6 of 6
    Jul 2013
    4
    Post Perske Spindle repair
    Hello All,
    I am in the process of rebuilding my CNC Router Spindle Perske VS 60.11.2.
    I am not able to remove the front bearing from the housing.
    There is a front shroud which is fixed before the bearing.
    I am not sure if it is slide fit or threaded to the shaft.
    I have tried heating the shroud and gentle hits with a rubber mallet. It did not budge.
    Haven't used a puller yet.
    Does any one have a drawing of the spindle?
    Attached a few photos for reference.
    Thank you,
    Antony.
    Apr 2016
    8
    Re: Perske Spindle repair
    Hi antony
    I had this same question but I have just realised that that this face plate on mine was just rusted on. I have another refurbished perske and this plate just slides off after the c clip is removed.
    Regards Peter.
    Apr 2016
    8
    Apr 2016
    8
    Apr 2016
    8
    Apr 2016
    8
  1. stripped perske spindle shaft
    By jonnyb in forum Spindles / VFD
    Last Post: 01-06-2019, 12:27 PM
  2. Which Collet for Perske Spindle?
    By sharp_custom in forum CNC Tooling
    Last Post: 06-21-2012, 05:04 PM
  3. perske spindle repair
    By Frode1 in forum Multicam Machines
    Last Post: 12-09-2011, 04:28 PM
  4. Perske spindle and VFD?
    By DennisCNC in forum CNC Machine Related Electronics
    Last Post: 06-14-2007, 11:40 PM
  5. Looking for info on a Perske spindle
    By HygloCompany in forum DNC Problems and Solutions
    Last Post: 04-20-2006, 10:20 PM
