586,075 active members*
4,029 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Mori seiki MV 40 Spindle Drive speed does not match S-code speed
Results 1 to 8 of 8
    Jun 2021
    8
    Lightbulb Mori seiki MV 40 Spindle Drive speed does not match S-code speed
    We have an Mori Seiki MV40 Milling center Fanuc 15MF, with a Fanuc AC Spindle Drive A06B-6059-H212. The S-code spindle speed commanded does not match the displayed spindle RPM on the drive. When a speed of S1000 is commanded, we see an RPM of approx 717, a difference of about 283. Spindle speed override set at 100%
    How can we make the speed match the S-code?
    Cheers,
    Hanzz
    Re: Mori seiki MV 40 Spindle Drive speed does not match S-code speed
    The speed on the drive is MOTOR speed not spindle speed. Unless you have a 1:1 ratio between the motor and spindle they won't match.
    Jun 2021
    8
    Quote Originally Posted by drdos View Post
    Thank for reply.
    My machine use Spindle type: Built-in Mottor. I removed the cover and found the gearbox. But there is no gearbox. Since the document related to the machine has been lost, the parameter has also been lost. I don't know how many rpm maximum spindle can rotate
    Can you post your paramewter file? Check parameter 5621
    Jun 2021
    8
    Parameter i was attachted with first post. Pl help me
    Quote Originally Posted by Hanzz View Post
    I need the CNC parameters. You only showed the PMC.
    Jun 2021
    8
    Hi Drdos,
    I send you the File Parameter.
    Thank you so much !
    Jun 2021
    8
    Hi drdos,
    Please Help Me. Thank you so much !
  1. mori seiki mv 35 spindle cant reach in commanded speed
    By karthick in forum Mori Seiki Mills
    Last Post: 03-20-2021, 12:08 PM
  2. Replies: 1
    Last Post: 09-28-2019, 03:44 AM
  3. Replies: 0
    Last Post: 02-28-2019, 04:46 PM
  4. Fanuc AC Spindle Drive speed does not match S-code speed
    By serickson in forum Spindles / VFD
    Last Post: 10-13-2014, 01:18 PM
