603,940 active members*
3,224 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal 6535 Z travel height
Results 1 to 10 of 10
Threaded View
EliteCustoms Fadal 6535 Z travel height 07-04-2021, 07:29 PM
machinehop5 Re: Fadal 6535 Z travel height 07-04-2021, 08:40 PM
EliteCustoms The SETP on size is set to 65... 07-04-2021, 09:08 PM
machinehop5 Re: Fadal 6535 Z travel height 07-05-2021, 01:32 AM
EliteCustoms I have also done this... 07-05-2021, 02:20 AM
machinehop5 Re: Fadal 6535 Z travel height 07-05-2021, 02:33 AM
machinehop5 Re: Fadal 6535 Z travel height 07-05-2021, 02:58 AM
EliteCustoms I’ll check that in the... 07-05-2021, 03:07 AM
machinehop5 Re: Fadal 6535 Z travel height 07-05-2021, 03:12 AM
EliteCustoms EPROMS I bought a new set... 07-21-2021, 12:25 PM
    Jul 2010
    21
    I purchased a 2001 Fadal 6535, it’s supposed to have 65x35x 34” travel.
    On the Z axis it will only descend 28” instead of 30”. I’ve changed the software module to a newer one (version 103.5) with no change on the distance of travel.
    I will attach pictures of the z axis motion board along with the cpu that shows software versions and EPROMs. Any help is greatly appreciated, I don’t want to run extended length tool holders to be able to reach parts or create sub plates to bring the table height up. I’d like to be able to use the t slots and keep the rigidity in tooling.
    Attached Thumbnails Attached Thumbnails A36F8E7D-2359-4C06-8517-77675B0C9A12.jpeg   62A87379-CDB9-445F-BFDF-6B72D836CD54.jpeg   1AE8B217-8FFC-42A7-B575-2890446CC37E.jpeg
  1. Fadal 6535 with Siemens Sinumerik 810d control doesn't recognize the tool
    By Mr.Peet in forum DNC Problems and Solutions
    Last Post: 06-25-2015, 02:46 PM
  2. Replies: 0
    Last Post: 02-06-2011, 08:23 AM
  3. Changing rapid travel height at the machine
    By Bigrhamr in forum DynaTorch
    Last Post: 08-06-2010, 06:59 AM
  4. Replies: 4
    Last Post: 01-28-2009, 10:50 PM
  5. OPTIMUM BF20L mill, z-travel exactly from table height ?
    By vroemm in forum Uncategorised MetalWorking Machines
    Last Post: 01-19-2009, 10:01 PM
