586,728 active members*
2,492 visitors online*
    6040 CNC controller/spindle issue
    My grandfather purchased a 6040 CNC machine by chinazone. I cannot find any markings of who makes the controller, the CNC machine is Model: CNCST4060AB3. Now I am not sure if the 4060 is just backwards in the model number or what. But after setting it up we can get the x,y and z axis to move but the spindle will not spin up. He had one of my uncles try to look at it and fix it, and when I came back over with what I thought would get the spindle going their is now an error. It is flashing P.oFF and the TRIP light is flashing along with the HZ light is lit up. I have tried following others instructions but they seem to be older controllers and do not look the same. And when I go into the P (settings?) and the D(settings) they are much different. In example P0.00 is set at 0.75 and cannot be changed. Can anyone help?? Thank you in advance
    Re: 6040 CNC controller/spindle issue
    I have the same problem with the same machine. I've been searching the internet for days. Can anyone help?
  1. Newbie to CNC issue with chinacnczone 6040 spindle
    By Iron_Geek_37 in forum Chinese Machines
    Last Post: 04-21-2020, 09:16 AM
  2. Newbie to CNC issue with chinacnczone 6040 spindle
    By Iron_Geek_37 in forum Spindles / VFD
    Last Post: 04-13-2020, 07:55 PM
  3. New 6040 CNC machine. Spindle controller settings.
    By RoddQLD in forum Australia, New Zealand Club House
    Last Post: 05-29-2018, 08:29 AM
  4. 6040 Spindle Issue with Mach3
    By snag96 in forum Chinese Machines
    Last Post: 01-30-2018, 11:50 PM
  5. CNC 6040 Setting or Other Issue - HELP!
    By DeeMaster in forum Mach Software (ArtSoft software)
    Last Post: 01-24-2016, 11:16 AM
