586,111 active members*
3,361 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Difference I/O signals via ExtIn board or INPUT OUTOUT connector
    Jan 2016
    19
    Hello,
    I have questions about the use of input and output signals via the ExtIn board.
    Several functions - like switching coolant or using a tool probe - require setting the I/O Pins in the settings menu.
    Here you find a pulldown menu that indicates only 8 inputs or 8 outputs.
    It is not possible to sellect the ExtIn signals.
    What if I want to use additinal inputs or outputs?
    So:
    1. Is it possible to adress a funktion like switching on/off the coolant to a relay on an additional relay board (through a ExtIn board)?
    2. is it possible to use a ExtIn board for the tool probe input?
    And when it is not possibel, which functions are affected?
    For me it is always a supprise
    Best regards,
    Marc
    May 2019
    28
    Quote Originally Posted by hoizlaender View Post
    Hello,
    So:
    Best regards,
    Marc
    The ExtIn signals and relays are controlled via scripting and may be used as desired …
    Jan 2016
    19
    Re: Difference I/O signals via ExtIn board or INPUT OUTOUT connector
    Quote Originally Posted by SkiPatrol View Post
    Hello SkiPatrol,
    thank you for your quick response.
    Even not knowing much about scripting I managed it to switch a relay on the EXT relay board by typing M3 in the MDI and switching it off by command M5.
    By clicking the icon on the desktop it didn´t work.
    But then I found the possibility to change the spindle Command from Native to M-code. (step 2.9.3.4.2 in the manual)
    I can go a little further now but I am sure that I come back soon with more questions.
    Best regards,
    Marc
  1. TNGv2 and the ExtIn board
    By tantemay in forum PlanetCNC
    Last Post: 04-24-2020, 07:44 PM
  2. mach3 not receiving input signals from C-10 breakout board
    By GUIDOSAN in forum Mach Software (ArtSoft software)
    Last Post: 12-01-2014, 07:41 PM
  3. Monitoring Input Signals
    By botha.y in forum SIEMENS -> GENERAL
    Last Post: 05-17-2012, 09:28 PM
  4. Ask for Fanuc OM-A M1/M2 connector signals
    By david_chen in forum Fanuc
    Last Post: 03-18-2011, 09:59 AM
  5. Replies: 2
    Last Post: 12-27-2007, 03:59 AM
