586,076 active members*
4,037 visitors online*
IndustryArena Forum > MetalWorking Machines > Turning Machines > Nakamura tome TW10 locking and unlocking the c axis
    Sep 2019
    Hi I'm working on a nakamura tome tw 10 and on the left side the service guy has replaced the spindle belts and also the the I think c axis encoder belt. Now the left side will not lock the c axis. You can turn off the power off and back on again and the c axis will rotate and find home and the m91 code will lock the c axis in place so we can create a saw slot in our part then it will unlock by way of m41 and it will run up to 20 parts and the left side c axis will stuck on m91 while it's trying to lock it. When replacing the c axis encoder belt does it have to be re timed? Thanks in advanced
    Frankie
    Sep 2010
    18
    Re: Nakamura tome TW10 locking and unlocking the c axis
    Hi Frankie! Did you solve this problem? I am now the owner of a TW10. Just starting to use it. Happy to share info!
    cheers, John
  1. Replies: 11
    Last Post: 10-20-2022, 11:22 AM
  2. Replies: 4
    Last Post: 12-16-2017, 09:57 AM
  3. nakamura tome TMC 20 enabling c axis and sub spindle mcode
    By dann0078 in forum Machinery Manuals / Brochures
    Last Post: 04-28-2017, 03:44 PM
  4. help ladder nakamura tome tw10
    By cucca in forum Fanuc
    Last Post: 10-20-2012, 08:56 AM
  5. Nakamura Tome
    By tpsimer in forum Uncategorised MetalWorking Machines
    Last Post: 06-21-2012, 09:34 PM
